Old 04-27-2010, 05:42 PM   #1
67chevy2wd
67chevy2wd's Avatar
Will a 73-87 8" lift work in my 71
I have a 71 GMC 3/4 ton that I want to put a lift in and I just found a 8" suspension lift for sale locally. It is out of a 73-87 style. Will it work in the 71 and is does it matter if it is a 1/2 ton lift or 3/4 ton? Here is the add
8" front springs,8" rear springs,4 shocks,front driveshaft,rear driveshaft,brake lines,2" drop pitman arm, 4" radial steering arm. $500.00 and thats the lowest price
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 04-27-2010, 09:09 PM   #2
Mike C
Mike C's Avatar
Re: Will a 73-87 8" lift work in my 71
No. At least not easily. Rear springs are same length, but fronts are not.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-28-2010, 11:10 PM   #3
70 beast
Certified Hobbiest
70 beast's Avatar
fronts are about 47" on 73-87 and 44" on 67-72.
a longer shackle may work and also if you moved the front hanger.
my jimmy build
http://67-72chevytrucks.com/vboard/s...d.php?t=352536
70 beast is offline   Reply With Quote
Old 05-02-2010, 06:05 PM   #4
bigbadchev72
People know me
bigbadchev72's Avatar
Yes, I have them in mine, I installed longer shackles in the rear and installed a zero rate to move the axle forward. It was still a liitle far back but not too bad. I have since then added a custom front crossmember to move the front spring hangers forward to get a little more flex out of them
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
