02-10-2003, 04:54 AM | #1 |
I Got My Engine!!!!!
Stupid P.o.s.!!!!!!!
Well my truck decided to go poot. It still runs but when i start it up there a clicking/ticking/knocking noise the gets faster as the rpms increase. It sounds like it coming from the back of the engine but i havent messed with it yet, (started tonight) will pull it in the shop and look at it tomorrow, but what should i be looking for?
Any help would be great. Cameron
F.O.R.D. "F*cked Over Rebuilt Dodge" -+-+-+-+Cameron+-+-+-+- 1987 GMC HIGH SIERRA LWB 1500 32X11.50 383 TBI/Vortec Heads/Intake MSD Ignition Dual Exhaust Custom Pinstriping Sweet interior & stereo http://www.cgalvin29.freehomepage.com |
02-10-2003, 05:09 AM | #2 |
blew a rod? my 305 had a severe knocking coming from the rear bottom of the engine.. didnt bother taking it apart to figure it out...
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
02-10-2003, 05:21 AM | #3 |
no i dont think so. say maybe bent but it runs really fine no power loss at all but just the clicking but i dont wanna run it till i get it fixed.
02-10-2003, 05:44 AM | #4 |
clicking? header collector gasket?
02-10-2003, 05:49 AM | #5 |
maybe, ill have to look into that
02-10-2003, 05:52 AM | #6 |
i need to do mine as well.. i can hear it clicking... annoying as hell..
02-10-2003, 07:10 AM | #7 |
Could it be a bad u-joint?
02-10-2003, 07:15 AM | #8 |
does it make the sound only when driving? or just when it is running?
02-10-2003, 07:16 AM | #9 |
Both, its a slower clicking at idle and then when i accerlate in increases with the rpms/speed
02-10-2003, 07:37 AM | #10 |
u-joint doesnt spin at idle. more than likely not it...
02-10-2003, 07:40 AM | #11 |
hmmm
02-10-2003, 09:34 AM | #12 |
You get what you pay for
It's definetely something which is engine rpm related, do drivetrain is not it because it's not moving. You will need to see where it's coming from, bottom or top? If top, it's probably a lifter or cam lobe going flat. A rod won't click. A rod makes a pecking sound sort of like pecking on the side of the block with something. Pecking sounds like lifter, rocker arm, pushrod, or cam to me.
If I were guessing, and this is all it is, a guess, I would guess at lifter or cam lobe. Probably cam lobe going flat. But don't panic until you figure it out.
Mike 1985 Chevy C-10 |
02-10-2003, 09:37 PM | #13 |
Genuine Chevrolet
If you don't turn up anything else and it's an Automatic check for a crack in your flex plate.
George 82 Silverado LWB 4x4 350 SM465 NP208 77 Chevrolet Blazer Chalet 400 TH350 NP203 |
02-10-2003, 11:31 PM | #14 |
5 day ban, learn to behave.
Can you tell if it happens every revolution or once every OTHER revolution?
once per rev is crank/rods/etc once every other will be valvetrain.. 8 out of 10 times it will be a flat lobe on the cam, a loose or worn rocker arm, or a cam lobe that went flat... get a stethoscope (a couple feet of heater hose), and remove the valve covers and start the motor and have a look mike |
