Old 04-27-2010, 09:21 PM   #1
stunna
Question LQ9 and LS1
i was told an LS1 and LQ9 are basically the same engine. The LQ9 are cheaper to find as a pullout. If i want to go with this setup, what should i look out for? Are there other parts to buy? Anybody done this swap?
stunna is offline   Reply With Quote
Old 04-27-2010, 09:40 PM   #2
Thealien
Thealien's Avatar
Re: LQ9 and LS1
a bunch of LS swap threads going on right now
Old 04-27-2010, 10:52 PM   #3
67ss&99ss
Andy
Re: LQ9 and LS1
They are not. An LS1 is an all aluminum 346 C.I. motor that came in camaros, trans ams and vettes. The LQ9 is 364 C.I. cast iron block, aluminum heads and it came in trucks mostly. The LQ9 has more tq than the LS1 but stock for stock, will not turn as many rpm as the LS1. Personally, I would rather have the LS1.
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi
1969 CST/10 383|Aisin AR5 5 speed
1972 K5 350|Turbo 350 4x4
2005 Duramax 2500HD 4x4
67ss&99ss is offline   Reply With Quote
Old 04-28-2010, 02:01 AM   #4
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Re: LQ9 and LS1
They are the same in that they are from the same engine family (GEN III) which is 4.8, 5.3, 5.7, 6.0, 6.2 and the big one 7.0. Also the LQ9 isn't that much more available than the LS1, it was only used in the sliverado SS and escalade. The LQ4 however is very available and cheaper.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 04-28-2010, 03:17 AM   #5
tapeworm
fan of "Butters" Stotch
tapeworm's Avatar
Re: LQ9 and LS1
http://www.ls1tech.com/forums/conversions-hybrids-28/
64 shortbox fleetside
replacing rusty junk with more junk, and one day to become a real truck again
tapeworm is offline   Reply With Quote
Old 04-29-2010, 12:12 PM   #6
stunna
Re: LQ9 and LS1
Originally Posted by tapeworm View Post
that was a great article! I wonder if thats the same member named"sticky" on this site?
Old 04-29-2010, 01:35 PM   #7
Jim_PA
Re: LQ9 and LS1
The only downside to the LS1 is that you can't do more than a bore cleanup without sleeving the block $$$$
Jim_PA is offline   Reply With Quote
