Old 04-28-2010, 12:22 PM   #1
reds_racing
Measuring Tailshaft?
I measured my Turbo 350 tranny tailshaft to see if it was 9" for my 700r4 swap. I measured from where it bolts to tranny to end of yolk. It is 9" between those two points. Did I measure it correctly? If so, the 700r4 is an easy swap with just moving the crossmember, Correct?
reds_racing is offline   Reply With Quote
Old 04-28-2010, 01:34 PM   #2
cdowns
cdowns's Avatar
Re: Measuring Tailshaft?
no you didnt measure right// its from to the end of the casting ,yoke is additional
the original tailshafts in these trucks were all 6"tailshafts
you need to move the crossmember and shorten driveshaft
Old 04-28-2010, 03:39 PM   #3
custom70
custom70's Avatar
Here is a picture showing the correct measurements.
custom70 is offline   Reply With Quote
Old 04-28-2010, 03:42 PM   #4
reds_racing
Thanks you very much. Mine is 6". Guess if I run the 700R4, I will have to have driveshaft shortened. Bummer.
Old 04-28-2010, 03:44 PM   #5
reds_racing
Hey CDowns, If I run the 200-4R, I don't have to modify driveshaft, is that right?
Old 04-28-2010, 04:12 PM   #6
cdowns
cdowns's Avatar
no driveshaft mods required for the 224R just reposition crossmember
Old 04-28-2010, 04:32 PM   #7
michael bustamante
michael bustamante's Avatar
is your truck a long or short bed? I m having to cut my d/s 3". (longbed)It was cut previously for a long tailshaft 350.
1967custom
michael bustamante is offline   Reply With Quote
