CAN ANYONE EXPLAIN WHY I KEEP BLOWING OUT OIL FILTERS? CHECK GAUGE LIGHT COMES ON, OIL SPILLS OUT.....THOUGHT IT WAS A BAD FILTER...CHANGED FILTERS, DID IT AGAIN. 95 CHEVY PICKUP. NEED HELP!!
Not sure what your mean by blowing the oil filter.......maybe blowing the seal?
You may have a blockage, and just keep building pressure.....
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
THE FIRST TIME IT HAPPENED, THE SEAL IN THE FILTER LOOKED LIKE IT WAS BULGING OUT. THOUGHT IT WAS A FAULTY FILTER. SECOND ONE DID THE SAME THING.
D.U.F. Member
Did you use the same brand of filer? Maybe try a different type and see if it does it again.
MEMBER OF THE DISCS UP FRONT CLUB '72 C-10 LWB Highlander, A/C, tilt TH350 w/ B&M shift kit, 327LJ bored .040", cast flattops, forged crank, L31 Vortecs, 9.25:1 CR, Comp conical valvesprings, Crane Energizer single pattern 216/.454", Professional Products Power Plus Crosswind intake, Edelbrock #1406 600cfm, HEI, dual exhaust, open 3.08 12bolt '68 C-10 4spd (not running) '79 C-10 LWB Mild 350 '80 Caprice Classic, 2-dr '97 GMC K-1500, SWB, Reg. Cab, Z-71, 5.7, Auto |
Got big-block?
![]() Join Date: Jul 2000
Are you sure it's the oil filter leaking?
Might be the o-ring seal on the oil cooler adapter if you have a factory cooler. The filter screws into the adapter which is bolted to the block. Mine started leaking - a lot - dripped right down the oil filter. I thought it was the oil filter at first, but it was the adapter seal. Real common once you get close to 100K miles. Just my 2 cents. SC
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
![]() Join Date: Jan 2003
This might help, check out http://cpgparts.alliedsignal.com/cpg...ressurized.pdf this is off the FRAM website and it talks about overpressured filters.
2013 Ford F150 FX4 2006 Chevy Silverado 1500 1982 Chevy C1500 2020 Ford Explorer Limited 2008 Ford Escape |
Red
My '89 Silverado started leaking from rear main seal, didn't have time to fix it myself so I took it in. The mech. told me the pcv system was clogged and the pressure was what blew the main seal. Could replace the seal, but it or something else would probably give way, that is why I'm shopping for a '69-'72 to buy now.
Don't know if this relates to your problem or not, but sounds possible? Mike |
| Bookmarks |
