Old 04-28-2010, 04:21 PM   #1
D.PASSMORE
One of the First
D.PASSMORE's Avatar
WTB 68 Grill/Hood Latch Assembly
Looking for a complete 68 hood latch assembly with all hardware. Need the pieces that attach to grill and the hood piece. Thanks David
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 04-28-2010, 04:25 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Re: WTB 68 Grill/Hood Latch Assembly
I still have this one for sale
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 04-28-2010, 04:47 PM   #3
Todd68Chevy
Todd68Chevy's Avatar
I have the hood latch assy. in this ad http://www.67-72chevytrucks.com/vboa...d.php?t=381556 and I should have the hood part and hardware. I will check tonight. Do you need the support that goes from the latch down to the front panel also? Thanks
Note: All parts I have for sale are also for sale locally.
I currently own: 1940 Chevy Fire truck (project), 1946 Chevy truck (project), 1946 Chevy 1 Ton pick up, 1953 Chevy school bus (storage area), 1968 Chevy C10 (I have drove for 26 years), 1994 Chevy C2500 (daily driver), 2005 GMC crew cab K2500 (parts hauler) and more trucks for parts.
Todd68Chevy is offline   Reply With Quote
Old 04-28-2010, 05:12 PM   #4
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I need every thing that is required to properly fit onto a 68 grill and bolt to the hood. Good solid metal and hardware... Price with shipping to 32084.
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 04-28-2010, 05:19 PM   #5
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Do you have the hardware and and hood peice? The grill and and hood is bare.
Old 04-28-2010, 05:59 PM   #6
CPNE
Resident Curmudgeon
CPNE's Avatar
By hood piece do you mean the part that latches to the hood release and is bolted to the underside of the hood? If so I can throw that in.
Only hardware required are standard bolts, if you want used ones I have those too. The only thing I may not have is where the brace bolts to the grill. IIRC this is a 3/8th or 5/16th headed bolt and a clip is required on the grill for it to attach too. That clip is similar to those in the fenders that the headlight bezels screws go thru, only larger. I'll see if I can locate something if you are interested.
Old 04-28-2010, 06:12 PM   #7
Todd68Chevy
If it does not work out with CPNE, I have this off of a 1967/68 for $35.00 including shipping (with out brace). I should also have the brace, if you need it I could also go (same as CPNE) $35.00 PLUS the shipping charges for everything. Thanks, Todd
Old 04-28-2010, 06:13 PM   #8
D.PASSMORE
One of the First
D.PASSMORE's Avatar
If you can get original hardware that bolts top latch assy to grill and the part that latches to the hood release with OE bolts. Give me total with shipping and go from there. Thanks
Old 04-28-2010, 06:16 PM   #9
D.PASSMORE
One of the First
D.PASSMORE's Avatar
Tood - CPNE is first up. Thanks for recognizing that...
DP
Old 04-28-2010, 06:23 PM   #10
CPNE
Resident Curmudgeon
CPNE's Avatar
If you can give me until Saturday I can get all these items rounded up. We had 10 inches of snow today but its going to be in the 70's by Saturday. I have a grill that probably has the smaller bolt I described, but it is buried right now.
If not, then go for the second offer, no hard feelings here.
Old 04-28-2010, 07:34 PM   #11
D.PASSMORE
One of the First
D.PASSMORE's Avatar
CPNE, I'll save you the agravation of having to dig and shovel. I seen the pictures of the snow! Alot of fun... And thanks... DP
Ok Todd, can you shoot me a PM with the details. Thanks
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 04-28-2010, 08:08 PM   #12
CPNE
Resident Curmudgeon
CPNE's Avatar
Mother Nature is going to do the heavy lifting, but its all good. Get the parts from Todd, what he has looks complete.
Old 04-28-2010, 10:00 PM   #13
Todd68Chevy
PM sent
