Old 04-28-2010, 08:04 PM   #1
jmag86
jmag86's Avatar
Question Turn Signals??
Hello everyone, I am a newbie to this site and my truck as well. I am having a problem and need help!!! Problem is my tail lights are dim as well as turn signals in rear, now when i put the truck in gear they get dimmer (can barely see them) and my turns signals flash the opposite. Meaning when i put on the left turn signal the right one flashes and when i put the right turn signal on the left one flashes but this only happens when truck is in gear.They work fine in park just dim.....weird huh??? Can any one shed some light on this subject?? Truck is 86 c10, got it bagged a month ago the tail lights worked fine before then maybe something happen when they took the bed off?
jmag86 is offline   Reply With Quote
Old 04-28-2010, 08:34 PM   #2
73chevyman
73chevyman's Avatar
Re: Turn Signals??
you might have 1 a bad ground or 2 a wire pinched some where even 3 if you have a trailer harness make sure no wires are spliced wrong... my truck reverse lights would stay on and the dash lights would come on when i put it in reverse... checked the trailer harness and found it was spliced wrong so i disconnected and everything works awesome...
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 04-28-2010, 08:42 PM   #3
jmag86
jmag86's Avatar
Re: Turn Signals??
i do have a trailor harness would they have cut it to get the bed off and spliced it back together? I am just asking cause it worked fine before the bags?
Old 04-28-2010, 08:44 PM   #4
jmag86
jmag86's Avatar
Re: Turn Signals??
And any idea where the ground might be for tail lights?
Old 04-28-2010, 09:17 PM   #5
Restrorob
The One And Only !!!
Restrorob's Avatar
Re: Turn Signals??
I agree with a bad/not connected ground lead, Most are on the driver side near the tail light screwed to a bed rail.
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 04-28-2010, 09:26 PM   #6
73chevyman
73chevyman's Avatar
Re: Turn Signals??
sounds like it could be pinched some where on the frame the harness run down the driverside... i would check that and what restrorob said
73 C10 Fleetside
Old 04-28-2010, 09:45 PM   #7
jmag86
jmag86's Avatar
Re: Turn Signals??
Thanks guys i will check it out!
