Chemist under the hood...
How much for a new clutch?
Well, my clutch was slipping really bad. The PO had the adjustment as far as it could go. I went to two different garages and the price is between $600 and $700 for new clutch and machining of the flywheel. Does this sound reasonable? I resigned myself to the fact that I can't do this myself. I just have the driveway and ramps to work with so just can't see how I can lift out the transmission remove the flywheel etc.
Thanks ![]()
Current fleet: 2013 GMC Sierra, 5.3L, 4x4 1988 GMC Sierra, 305, Auto 1984 Jeep Grand Wagoneer, 360 V8 1997 VW Cabrio, 2.0L 2017 Toyota Rav4, 2.5L Stuff I wish I still had: 2013 Toyota Matrix [RIP] 1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD] 1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD} 1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD] 1995 Chevrolet Astro AWD, 4.3L V6 (RIP) 1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD] |
Junior Member
Re: How much for a new clutch?
I put a new clutch kit and flywheel on my 454 before we put the engine in my '71 C-10. I got everything at Auto Zone for right at $200.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
its basic stuff to pull your trans. honestly id never pay to have one done especially not in something as simple as your truck. but if your deadset on not doing it that price is a good price for parts and labor
1967 c-10-built smallblock, backed by m-21, lowered 2005 silverado-tint, exhaust, lift, 35's 1964 c-10 shortbed project |
#4 | |
The assembly is $250 up here in Ontario. I found a lower price of $185 at parts place but he wasn't 100% sure it would fit my 283 housing.
its all very simple ive done mine in a night with numerous beer breaks. i may be a mechanic for a living but believe me its nothing but nuts and bolts and you or any other guy with a set of american sockets can do it
1967 c-10-built smallblock, backed by m-21, lowered 2005 silverado-tint, exhaust, lift, 35's 1964 c-10 shortbed project Last edited by wp silverado; 04-28-2010 at 09:26 PM. |
How do you do a clutch job in a night?Is there a night time machine shop for facing the flywheel?If it`s a 4spd that`s pretty tough alone and the flywheel part is what makes it a job.It`s always a pain to lock and break loose as well as torquing down.That sounds like a good price considering I spend close to $500 for my Centerforces I do myself.
in a night easy. flywheel was turned at work, granted he does'nt have that option it can still be done in a day stopping to take the flywheel to a shop and have it turned
hey, you could buy a jack & trans adapter and get it done on a weekend . check with the auto parts store of your choice to see if they could surface your flywheel on a saturday & put it together on sunday! try it, clearly you have nothing to loose but $$$$ call a friend to help ya! best of luck, Pat
bought one for my car with new flywheel for around 200 but i know thats way different then our trucks.. but the 6-700 most is labor im sure.. they are easy to replace its just time consuming.. i did my car in three days because it was front wheel drive four cylinder so being it rear wheel drive u dont gotta drop trans so im sure this is way easier.. if a 19 year old can do it with ease i bet u can do it with no problem
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
Location: Smack-dab in the middle of "The land of fruits and nuts", Sacramento, CA
First of all, the price you mentioned for parts and labor does not seem out of line. As you already know, there is close to $200 worth of parts involved. The question then becomes how much work (and time) you are willing spend to save five hundred dollars. I hope I can encourge you if you reconsider doing it yourself. I am doing the clutch (my first time ever!) on my ‘68, in my driveway, and I did NOT have to jack the truck off the ground. I don’t have an impact wrench or any special tools. It took an hour or so to unbolt the driveshaft, shift linkage, clutch linkage, etc. I had a drain pan under the trans when I removed the speedo drive to drain the oil ( my trans has no drain plug!) Next, I bought a pair of four-inch long bolts at the hardware store, cut off the heads, and screwed them into the bellhousing to guide the trans onto my floorjack. My truck has an “apron” style bellhousing . . . there is a stamped steel inspection cover on the lower section. After removing the cover, I was able to remove the clutch fork, the driven disc, the pressure plate, and then the flywheel without having to remove the bellhousing! I found a spare pressure plate bolt and used it to hold a piece of bar stock to lock the flywheel when I removed the flywheel bolts. I have spent more time so far cleaning parts than actual “wrenching” time. BTW, my local machine shop gets $35 to resurface the flywheel and can do it in one hour. Anyway, if you have done a complete brake job (with turning drums, bleeding the hydraulics, cleaning/packing bearings, etc, etc.) you should find replacing the clutch just as, if not a lot more, easy than brakes, especially if you have the two-piece bellhousing like mine. Again, just some encouragement if you decide to DIY.
the prices you were quoted dont seem bad// if you dont feel comfortable doing it yourself theres nothing wrong with farming it out
worst case you get egged on to try and do it yourself then it gets screwed up and then you need to buy the same parts twice plus more
HINT: Living in a house with no garage and only a gravel driveway, a transmission jack is worthless. I found using a ratcheting strap very in lifting and holding the tranny while positioning and bolting in!
Necessity is a Mother!
![]() 383 Stroker - Edlebrock Air Gap intake and 670 CFM Holley Street Avenger carb. Hooker Comp Headers w/ X-Pipe and 2.25 duals TKO-500 & 3.08:1 rear I Love HEMI's, they're soft & chewy! ![]() |
#13 |
Junior Member
I guess it depends on the transmission. One time I replaced the clutch on my '72 GMC with a granny 4 speed without dropping the transmission.
I just removed the high hump, strapped the transmission to a couple of 2 bys and slid it back. Now a 3 speed would not really pose a weight problem compared to the old 4 speeds, but it would be nice to have a helper. The last clutch we replaced was pretty easy since we pulled the 350 and put the clutch on the 454 before putting it in. My son and I are pretty hands on when it comes to working on these old trucks, but do have to farm out any machine work on the engines. If you have the money and don't have the time or feel comfortable doing it might as well have a shop do it. Danny
#14 |
My Carbon Footprint
If you do it yourself, watch the ramps! Many have met the maker with those things!
#15 | |
Active Member
![]() Join Date: Jul 2007
Try it yourself if: Have the time to do it Have access to or can rent a trans jack Have proper tools Won't take short cuts like not replacing parts 'cause they look okay Can afford to re-do it if parts are defective (has happened to me) Other wise let them do it and make sure that there's some sort of guarantee in writing for labor and parts. |
#16 |
![]() Join Date: Apr 2000
The way I was taught to take a transmission out (over 40 years ago) is to unbolt it, lie under it, pull it out and set it on your chest then roll it off. Installation is the reverse. Cant remember how many I did in the rain and snow and mud. Good luck.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
#17 | |
Junior Member
If it is the old 4 speed and you do it that way you are a lot stronger than I have ever been, lol. It is funny now, but it wasn't then. You should of seen me and my son try to put the old style 4 speed on the I-6 in my '67 using brute force. We thought it about it later and could have used a cherry picker. I have tried the transmission jack attachment for a floor jack and really did not like it. Danny
#18 |
Thanks for all the encouragement but I would say the comments were about 50/50 for doing it myself so.....I gave it to the pro. Its killing me but that's such a big part of the truck and the part isn't all that cheap if I screw it up.
Really appreciate the stories too. Don't really have a like-minded buddy to help out sadly so I really do most stuff all by myself ![]() I'll let you know when it comes back from the shop. Take care. ![]()
#19 |
A clutch set can run (stock) anywhere from $106.00 to a little over $400.00. for your truck
STOCK PARTS not aftermarket depends on size and part number then the labor These are our prices Last edited by mbgmike; 04-29-2010 at 07:29 PM. |
#20 |
Active Member
#21 |
![]() Join Date: Sep 2005
i paid 260 for an ac delco clutch for my truck. took bout 3 hours to install in drive way with no transmission jack. the 3 speed only weighs about 50 lbs
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
#22 |
Sorry-Mine is a 4-speed muncie=heavier. I should be getting it back from the shop this week. I'll let you know.
#23 |
Well, the truck came back. The mechanic said it was the most worn out clutch he'd ever seen (and he's over 50) and was probably only touching on the top edge. The shifter was so bad he actually pulled it straight out (oops). So, now it drives like a completely different truck! I think it was worth it. What a difference in clutch travel too.
Thanks for all the advice.
#24 |
Active Member
