Old 02-28-2001, 08:41 PM   #1
Desert Rat
Desert Rat's Avatar
Post What year was Power Windows and Locks offered?
Looking to install in a 73.
Desert Rat is offline   Reply With Quote
Old 02-28-2001, 11:41 PM   #2
Chevyman69
Vortec 350's Suck
Post
The first years for power windows and locks was 1977. With that in mind you should be able to pull the whole setup from a 77 up truck including wiring and all the internals of the doors and install them on your 73. Of course the complete door off a 77 truck would be a good swap also for the setup without as much disassembly and reassembly.
69 CST, 402 steel crank, heavy rods polished ported heads 2.19/1.88 should be 450+ 700R4 373 Posi buckets/console tilt tach 4wheel discs
Daily Driver: 92 Chev 4x4 350 auto
69 Chev CST 10 reg cab lwb
Daily Driver: 92 Chev Reg Cab LWB Silverado 4x4, K.I.A 7:51 AM 04/22/03
Will be resurrected
Chevyman69 is offline   Reply With Quote
Old 03-01-2001, 07:26 PM   #3
CaptkaosCustoms
Post
Tried to post this last night, but my account is all screwed up right now. So I registered again.......
It was 77, 77-91 doors are the same. You will need to change the complete door. 73-76 doors can't be used for the power motors. Here is a pic of the comparison. I can tell you what the problems will be if you can tell from the photos.
73-76 door
77-91 door
There are also 2 versions of the power motors. The early style 77-80 are a little stronger/bigger motor than the latter.
Chris Lucas
www.captkaoscustoms.com
Chris Lucas
CaptkaosCustoms is offline   Reply With Quote
