Old 04-28-2010, 10:31 PM   #1
kcfirstbuild
Help ! Help ! Help!
I just pulled my 307 and trans out with a cherry picker and i'm wanting to mount it on my engine stand. so, i know that i have to remove my trans from the motor. I removed all the bolts from the bell housing and was able to separate it about an inch or more, but I can't go any further. I asked around and they said it should just slide off. Well its not ? Not sure what kind of Trans i have but its a three on the tree.
also does the flywheel stay with with the motor of with the trans when they are separated?
kcfirstbuild is offline   Reply With Quote
Old 04-28-2010, 10:43 PM   #2
El Jay
Gone to greener pastures
Re: Help ! Help ! Help!
Set it down, on the floor and wiggle the transmission. Sometimes the input shaft gets hung up in the pilot bushing.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 04-28-2010, 10:45 PM   #3
leddzepp
Moderator
leddzepp's Avatar
The flywheel stays attached to the crankshaft on the engine. ElJay answered your other question.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 04-28-2010, 10:50 PM   #4
kcfirstbuild
OK ill try setting it on the floor,but im not sure if my picker will go that low. I'll try in a day or so. Thought the flywheel stayed with the motor cause i could see the housing move but not the fly. I did alot of wiggling though. I had the picked low and the trans supported my a jack.
Old 04-28-2010, 11:32 PM   #5
basemodel67
Factory Strippers Rule!
basemodel67's Avatar
Yikes! Be careful taking stuff like that apart when it's not on the ground... it weighs A LOT more than you will be ready to catch when it let's loose.
"Feast your eyes on a feast of smoke."
67 Chevy Short Fleet
PLAN: LQ9, 4L60, D60
Looking for School Bus Gauges - Help me out!
basemodel67 is offline   Reply With Quote
Old 04-29-2010, 12:35 AM   #6
El Jay
I forgot to answer the flywheel part. Thanks for covering my butt, Scott.
Old 04-29-2010, 12:55 AM   #7
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
If it won't go all the way to the floor then put it in the bed of the truck on a sheet of plywood. Like stated above it won't let go until you take the tension off of the input shaft. Good luck!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 04-29-2010, 01:02 AM   #8
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Lower it down so the trans sets into a kids wagon. Then pull on the wagon... I watched a buddy of mine do that with a Ford 302 and a T5...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 04-29-2010, 08:14 AM   #9
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
When I did mine I used two old tires and sat the motor and tranny on them worked great.
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 04-29-2010, 11:56 AM   #10
Jacfourteen
I've never used a tire for a tranny, but any time I have an engine out I set it in an old tire. The oil sump fits nicely in the sunken in part of the wheel. It works well for when you have to haul one in the back of a truck too.
Old 04-29-2010, 09:14 PM   #11
kcfirstbuild
Well i got them apart. I didn't unbolt the little pan that is on the bottom of the trans. After that the trans popped right off. Thanks for all the help everyone.
Old 04-29-2010, 11:35 PM   #12
Jim_PA
That sounds a lot like the way I operate. Thanks for giving me something to relate to
Jim_PA is offline   Reply With Quote
Old 04-30-2010, 12:04 AM   #13
Jacfourteen
Me too, I've pulled some pretty bone head moves before.....even a few that have landed me in the ER
Old 04-30-2010, 07:01 PM   #14
kcfirstbuild
I have only changed spark plugs, wires and rotated tires before. So pulling a motor and trans out and rebuilding a whole truck is really new to me. I told my dad this would go alot faster if either on of us new what we were doing. But, between the both of us we have alot of people we can call if we need help.
Old 04-30-2010, 07:08 PM   #15
kcfirstbuild
OH off the subject. I notice the fly wheel ring gear has started to get a bevel to it and looks like i should get a new one. I checked in to a new one and its rather cheap. I figure since im replacing the clutch ill replace that as well.
