Old 04-29-2010, 01:51 AM   #1
tattoojoey
tattoojoey's Avatar
upgrade front clip from 74 to an 89??
i bought a 74 swb! what do i have to do to put an 89 front clip on my trck??can anyone help???thanks!
tattoojoey is offline   Reply With Quote
Old 04-29-2010, 05:50 AM   #2
harnalien
TruckincrazY
harnalien's Avatar
Re: upgrade front clip from 74 to an 89??
That's a good question because I wanted to do the opposite. I wanted to put an older front end on my '84. Hopefully you get some answers that could help me too! Cool truck!
harnalien is offline   Reply With Quote
Old 04-29-2010, 06:35 AM   #3
Restrorob
The One And Only !!!
Restrorob's Avatar
That's not a 74 grille in your truck.....And the body lines on a 89 will not match the older trucks, They are totally different.....
93 Jeep XJ
88 Buick La Sabra
Toys;
88 TA-GTA in the works....
97 GMC Ext. Cab
Old 04-29-2010, 07:57 AM   #4
Cherub
Cherub's Avatar
its not the body lines that are different its the front frame horns that are different that doesnt allow you to just swap the newer coresupport over. Its doable though but you would mounts fabbed up.
Cherub is offline   Reply With Quote
Old 04-29-2010, 08:36 AM   #5
bigblock73
yeller
bigblock73's Avatar
Guys, he may be referring to a 89 Burb/Blazer clip...at least I would hope so.
bigblock73 is offline   Reply With Quote
Old 04-29-2010, 11:32 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
But it has been done. When the 88-98 style came out there was a local guy that had the front end morphed on to a 73-87. It was not pretty.
I agree with Jeff though, I "think" he is referring to the Burb front clip.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-29-2010, 12:10 PM   #7
Restrorob
Restrorob's Avatar
The body lines being different is reason enough a swap shouldn't be done as N2 mentioned.
93 Jeep XJ
88 Buick La Sabra
Toys;
97 GMC Ext. Cab
Old 04-29-2010, 12:16 PM   #8
bigblock73
yeller
bigblock73's Avatar
You guys are confusing me..uugghh
OBS 88-91 clip will fit your 73-87, pretty much like a glove. The core support just needs the bushings that match the frame of the truck it is going on...no "fabbing" required to make it fit. There are some other things to consider, that have been covered here on the board a zillion times. I would mention all of them, but time is not on my side...however the search button does work and should net you countless hours of reading regarding front clip swaps.
Old 04-29-2010, 12:43 PM   #9
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Originally Posted by bigblock73 View Post
OBS 88-91 clip will fit your 73-87, pretty much like a glove. .
Exactly. Mine is off of a 91.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 04-29-2010, 08:31 PM   #10
longbedrick
longbedrick's Avatar
FWIW, I vote you keep the round headlights and clip
longbedrick is offline   Reply With Quote
Old 04-30-2010, 01:39 AM   #11
tattoojoey
tattoojoey's Avatar
yea its a 89 burban clip!and its off about 1in on top of the fender where it meets up to the door and sticks out about 2in from the "A" pillar like it hitting the side of the firewall! and my front end is a 74 on my truck!but i put the 89 burb clip and it doesnt line up to well!doors fit perfect but the frnders are not lining up!i used the old core support mounts on the new clip and i still doesnt line up!! thanks for all the feed back guys! oh and yea when i put my old clip on the burb it fit right on!!
Old 04-30-2010, 01:43 AM   #12
tattoojoey
tattoojoey's Avatar
@harnalian yea the old front clip will go right on! When i swapt it out mine fit right on the that 89 burb!like a glove!but im having a hard time puttin the newer one on my truck!
Old 04-30-2010, 03:07 AM   #13
harnalien
TruckincrazY
harnalien's Avatar
Very interesting! I like this look and am interested. I already need a new hood, so I just need fenders and radiator support? Well obviously the the lights and grill and stuff. Is the wiring pretty straightforward?
