04-29-2010, 01:54 AM | #1 |
VA72C10
American Autowire 500703 complete wiring harness/fuseblock
New in the unopened box. American Autowire 500703
Labeled every 2-3" for easy installation. Comes with Billet headlight knob PRICE DROP!!! 265 plus actual shipping!!!! SAVE 100 I accept paypal (if you add the fees) HIGHWAY 15 WIRING KIT, complete panel and full wiring kit The Highway 15 is a brute in a small package. Built with the same heavy duty internal components as those used in our Highway 22 panel, it can easily handle the basic power requirements of any vehicle. Its size makes it the perfect power center for roadsters, T- buckets, kit cars, race cars or any other vehicle where basic operational circuits are required. Heavy gauge lead wires are provided for battery, ignition, accessory, horn, turn signal flasher, and 4-way hazard flasher. Best of all, it is also designed around the same step-by-step installation approach employed with all of our systems. Easy clamp-style system makes adding and removing wires easy! No Terminals! No Crimping! No Screws! Ignition switch Included. Connections included for either dash or column mounted ignition switches. All needed terminals and connectors to finish the basic wiring system are included. Complete wiring for headlights. (Headlight switch included with internal circuit breaker.) Mounting legs are moveable to allow for various mounting situations. Alternator regulator diode included. Micro-Relays for Horn and signals. 15 output connections! Floor mounted dimmer switch Included! 3 position head-light switch! Heat Resistant Nylon 6/6 Construction Throughout! Designed with internal circuit breaker protection (Billet knob included). Unique design of "gauge cluster disconnect " makes connecting up to 8 gauges simple and convenient. Heavy 8-Gauge alternator power feed wire! High heat and abrasion resistant XLPE wire. Wire withstands -60°F to +275°F! Additional Features: 1.Complete engine compartment wiring for oil pressure, water temperature, starter, neutral safety switch, ignition switch, distributor coil, main power feed, alternator and regulator. 2.Coil leads supplied with connector for GM HEI distributor. Bypass wire included for point type distributors. 3.Headlight circuit complete with circuit breaker for headlight switches without integral circuit breaker. 4.Complete wiring for all running lights, brake lights and directional lights, and license lights and third brake lights. 5.Dash wiring included for electric gauges such as oil pressure, water temp., voltmeter, fuel gauge, and tachometer. Dash lighting for all gauges, speedometer, turn signal & high beam indicator lights. 6.Complete wiring for steering column including horn, directional signal switch and 4-way hazard switch. Standard 3-7/8" GM column connector (both male and female) are provided to directly plug-in to any '69 -'74 GM steering columns. Connector bodies and terminals are pro- vided to also make mating to any make column a breeze! 7.Complete wiring for radio, heat and A/C, and wipers. 8.Spare battery and accessory circuits 9.All fuses, flashers, and relays included. 10.Horn relay on panel. 11.Standard turn signal and hazard flasher circuits. 12.Circuit breaker capability on 1 battery and 1 accessory circuit. 13.Wire circuit ink-jet labeling every 2" or 3". 14.Heavy duty terminals and internal power buss. 15.Rugged factory terminals and terminations within the fuse panel assembly. 16.Color schematics and easy to understand installation instructions included. 17.Patented Hooke’s Law, Screw down connection system
Looking for a 67-72 swb or blazer project in or around VA. Last edited by VA72C10; 12-09-2010 at 10:50 AM. |
04-29-2010, 07:26 AM | #2 |
Re: American Autowire 500703 complete wiring harness/fuseblock
I will likely need this - let me check and let you know in a bit...
**sorry - I was looking for a 510089 kit** - I am passing. Last edited by lks dcvn; 04-29-2010 at 07:28 AM. Reason: need another kit |
04-29-2010, 08:25 AM | #3 |
let me do some research... very interested...
04-29-2010, 02:14 PM | #4 |
This isnt the 67-72 kit is it?
Eric 70 CST10 long bed in pieces also factory air and cruise(the project) 18 Silverado crew cab 5.3 4x4 My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=402166 |
04-29-2010, 03:17 PM | #5 |
VA72C10
no, it is a universal kit for adding things like power windows, doors,etc. for those that shave or modify their firewall. It does have a correct GM connector for the steering wheel and ignition/headlight switch.
Looking for a 67-72 swb or blazer project in or around VA. |
05-25-2010, 10:58 AM | #6 |
VA72C10
I'll go 325 shipped...
05-27-2010, 09:34 AM | #7 |
VA72C10
Price drop 315 shipped firm!
05-29-2010, 01:20 PM | #8 |
VA72C10
OKay, 300 shipped FINAL OFFER before I keep it
05-30-2010, 12:32 AM | #9 |
VA72C10
ttt
12-01-2010, 09:51 PM | #10 |
VA72C10
ttt
12-04-2010, 11:47 PM | #11 |
VA72C10
ttt
12-06-2010, 09:38 PM | #12 |
VA72C10
Alright.....265 plus actual shipping...need some funds more than this right now...
12-14-2010, 11:36 AM | #13 |
VA72C10
ttt for a deal!!!!
12-15-2010, 05:05 AM | #14 |
do you know if this is plug and play for the ignition plugs and steering column plugs feel free to pm me. Will it work with my 72 blazer
thanks |
12-15-2010, 01:52 PM | #15 | ||
VA72C10
12-15-2010, 07:12 PM | #16 |
Do you know if it would it be a lot more work to use this kit versus a specific kit for a 67-72 chevy truck? I'm not a wiring expert so I'd hate to buy this thinking I got a deal and end up spending a lot more time trying to get it to work.
12-15-2010, 07:17 PM | #17 |
VA72C10
I got it because I planned on aftermarket gauges, vintage air, and some additional lighting in the cab. If you're going 100% stock it might be worth your money to get a factory correct kit to save time...
12-16-2010, 02:57 AM | #18 |
let me check my piggy bank, I am very interested in the harness.
12-16-2010, 02:58 AM | #19 |
oh yeah and I will also come to pick it up so you dont have to worry about shipping
12-18-2010, 01:06 AM | #20 |
pm me your address I need to mapquest how far it is to your house. If still available I will take the wiring harness.
thanks |
02-21-2012, 04:35 PM | #21 |
member
Did you ever sell this? Thanks
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide |
02-21-2012, 06:09 PM | #22 |
VA72C10
yes, 72blazer got it. Check on ebay though. I've recently seen some pop up there for similar to what I was asking.
