Old 04-29-2010, 04:20 AM   #1
mikeone87
Question self adjusting TCI TV CABLE BRACKET ??
idk guys, you think its too good to be true ??
http://www.tciauto.com/WhatsNew/File...ablesystem.pdf
"Making sure your 700R4 or 2004R transmission throttle valve (TV) cable is properly adjusted is
essential for providing exact shift points and maintaining the life of your transmission. The TCI®
EZ-Shift TV Cable Correction System is a self-adjusting complete package that includes a TV
cable, TV cable carburetor cam, throttle cable attachment arm assembly and throttle cable
bracket assembly that fits most popular throttle cables. The kit components’ steel and aluminum
construction provides unmatched durability and performance."
mikeone87 is offline   Reply With Quote
Old 04-29-2010, 12:26 PM   #2
Indyuke
Re: self adjusting TCI TV CABLE BRACKET ??
Sounds plausible. I know that's how some Ford pickups were adjusted at the factory with the AOD transmission. They just clipped the cable on, cycled the throttle and it was done. Roll it out the door.
Maybe that's why the Ford AOD has always been known to be a transmission of questionable strength.
Edit: In looking closely at it, it think it's virtually identical to the bowtie kit. The only thing it lacks that the bowtie kit has, is the adjustable cam for minor shift point adjustment.
Indyuke is offline   Reply With Quote
Old 04-29-2010, 12:45 PM   #3
rsavage
rsavage's Avatar
Bow Tie Overdrives has had such kits available for quite awhile and in fact cover more carbs including Q-jets. There are a number of factors for proper cable adjustment including an arc, throttle open 1/4 when perpendicular to carb base, length of pull when at full throttle, etc. All the cables self adjust on set up, but all the other factors have to be figured in. That's why I think they would be a good idea as they have a cam system that provides the 70 degree arc. I don't have one of the carbs covered as mine is currently a rochester 2 bbl. I had to make a bracket and according to a pressure check in each gear, it seems to work okay. Next winter when I replace the 307 with a 350 Q jet, it will have one of the engineered systems.
There is also a constant pressure valve body made by TCI that supposedly protects against improper TV cable adjustment and transmission damage. It is around $200. Never used one so can't say how they work but it seems like a fairly inexpensive insurance policy if you had a very expensive 700R4 or 200 4R.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
