Old 04-29-2010, 11:09 AM   #1
cweber
Qustion about a flip kit
Im going to do a rear end swap and was wondering if a flip kit is as simple as just putnig the rear end on top of the springs instead of buying the kit? What does the kit include?
cweber is offline   Reply With Quote
Old 04-29-2010, 11:31 AM   #2
72GREENC10
72GREENC10's Avatar
Re: Qustion about a flip kit
well, i did my own flip, all i did was buy a set of new perches from a suspension shop for 2.5 leafs, and it was as simple as measuring it and welding it, i got a good 5 to 6 inch drop with no problems other than bottoming out when im hauling a$$, other than that i costs a total $40.00 and am happy with it.
72GREENC10 is offline   Reply With Quote
Old 04-29-2010, 11:31 AM   #3
JWall
Frequent Flyer
JWall's Avatar
Generally the items below plus hardware...
- Justin
1 Owner 1976 SWB
Old 04-29-2010, 12:51 PM   #4
cweber
This is on an 84 btw. So what will i need to do if i just flip the alxe
Old 04-29-2010, 01:35 PM   #5
SCOTI
SCOTI's Avatar
Either do as mentioned (cut off the old saddles & weld new ones on the housing) or, for a 'bolt-in' deal you'll need the relocation brackets in the top right hand corner of the pic above @ the least. Prob is, I don't know of anyone that sells only the brackets. They sell 'kits'.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-29-2010, 01:47 PM   #6
cweber
Thanks for the info guys!
Old 04-30-2010, 07:49 AM   #7
875.3CHEVY
doesnt a flipkit have the holes offset to keep the wheels centered.cause if you just welded the saddles to the rearend it would slide it forward.thats what i thought.you can see it in the kit picture where the spring plate hole isnt centered.
875.3CHEVY is offline   Reply With Quote
Old 04-30-2010, 08:57 AM   #8
SCOTI
SCOTI's Avatar
Correct.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 04-30-2010, 10:06 AM   #9
nlped
nlped's Avatar
I build flip brackets for the '73-87 . I am also working on a c-notch, spring plate etc. to offer a complete flip kit for these.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
