Old 04-29-2010, 01:36 PM   #1
b4mytime
Need to rebuild Rear end
Can anyone point me in the direction of a rebuild kit for a 1967 C20 suburban?
b4mytime is offline   Reply With Quote
Old 04-29-2010, 06:29 PM   #2
Burb
Coordinator of Synchronicity
Burb's Avatar
Re: Need to rebuild Rear end
What do you have ... a Eaton, a Dana ??? And what is the bolt count?
Rick
1971 Suburban ... W.I.P. Build Thread
Customization is ones personal touch-- not what other people think it should be
Burb is offline   Reply With Quote
Old 04-29-2010, 08:28 PM   #3
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
rebuild kit as in what? diff. brakes suspension what lol
John
1999 Toyota Tacoma 4x4
Old 04-29-2010, 08:46 PM   #4
vectorit
What?
vectorit's Avatar
Welcome to the board fellow Suburban owner!
If you are not sure about the question above, as in what type of axle you have which is important.
Is the differential cover round? if it is, it's an "Eaton" style axle.
If the differential cover is other than round, it will be a "Dana" brand most likely.
Eaton's are difficult to get some important parts for, especially if you want to do a complete overhaul. Gear set choices are slim, and some bearings are tough to locate. Plus, add to that a lot of axle shops won't want to work on an Eaton. Personally, if a shop poo poo's an Eaton then they are not all that any ways. So it's just a sign to you to move on to the next shop.
Dana's are very common, and getting parts/gears is pretty easy to accomplish. Enough said on that.
Both axles are tough units none the less.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 05-04-2010, 03:44 PM   #5
Burb
Burb's Avatar
The Eaton only came out with 2 or 3 three gear selections right
4.10 4.56 ... ?
Rick
Old 05-04-2010, 09:54 PM   #6
oldblue1968chevy
sounds right..
John
Old 05-05-2010, 11:20 AM   #7
b4mytime
I havent looked yet. Its is said to be a factory Posi rear end. I will look to see if its an Eaton or a Dana ASAP.
Old 05-05-2010, 12:00 PM   #8
b4mytime
I am fairly sure its one of the bearings at it doesnt sound like the normal rear end growl.
Old 05-05-2010, 12:06 PM   #9
Burb
Burb's Avatar
quick check ... glance under the truck and look @ the cover ... if it is perferctly round ... you have an Eaton.
Rick
