Old 04-29-2010, 07:48 PM   #1
big mike71
big mike71's Avatar
Tire size and speedometer
If my new tires are about an inch taller than the old ones, and I'm going 55 by the speedo will I be going faster or slower than with the old ones.
I'm not as good as I once was, But I'm as good once as I ever was.
big mike71 is offline   Reply With Quote
Old 04-29-2010, 07:51 PM   #2
handsomerob
handsomerob's Avatar
Re: Tire size and speedometer
Faster
handsomerob is offline   Reply With Quote
Old 04-29-2010, 07:57 PM   #3
big mike71
big mike71's Avatar
That's what I thought, But I drank so many beers while I was putting them on I wasn't sure. Thanks
Old 04-29-2010, 08:07 PM   #4
handsomerob
No prob, I'll give a brief explanation although you may not care,
say with your normal size tire you are traveling @ 55mph and the engine is running @ 2700 RPM now say you stock tire was 30 inches tall thats a circumferance of 94.25 inches so for every rotation your truck moves 94.25 inches.
Well now take that same RPM and a 31 inch tall tire, that tire would move you 97.4 inches per rotation.
so your speedo says it 55mph cause its calibrated for the stock tire size, but in reality you are moving faster.
hope that makes sence.
Old 04-29-2010, 08:24 PM   #5
D-Rat
D-Rat's Avatar
what size tire was standard on a '70 2wd CST, and what is the metric equivelent, height wise? I know the tires I have a shorter than stock and I'm not going as fast as the truck says, also meaning, the odometer is rolling faster than it should.
1970 CST with a screaming 400
www.nissan4wheelers.com
D-Rat is offline   Reply With Quote
Old 04-29-2010, 08:27 PM   #6
big mike71
big mike71's Avatar
Good explanation.
Old 04-30-2010, 03:53 PM   #7
grs
If the city has a radar sign. Drive your truck, and see how fast it says you are going. Then see what your speedo says. When the radar sign says I am going 35 mph my speedo says I am going 30 mph. They move these radar signs around town, so look for one, or call the police dept. and ask where one is.
grs is offline   Reply With Quote
Old 04-30-2010, 04:48 PM   #8
Quackaddict
"Hooked on Quack"
Also another way to check is if you have a friend with a GPS everyone I have ever used will also tell you how fast you are going..........I am about to have this issue as I am going to be running either 37's or 39's when I am finished so I am gonna have to figure out how to change the speedo gear.......yeah
Semper Fi,
Kevin
USMC
Quackaddict is offline   Reply With Quote
Old 04-30-2010, 07:20 PM   #9
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
Here is a nice little applet shat will show you the differences in tire sizes, including revolutions per mile.
http://www.miata.net/garage/tirecalc.html
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
