1969 Custom 30 wrecker
Can someone explain how grease is supposed to go into the upper A arm shafts on these trucks?
I have 2 of these trucks, a 69 & 71. Some of my A-arm fittings actually take grease but some just won't and never have! I recently put 2 new upper A-arm shafts in one of my trucks and can't get any grease to go into any of the 4 fittings. I took one back apart to see what could be wrong and don't see any way the grease can go anywhere. The grease fitting is on the end of the big nut, the nut gets screwed onto the shaft and that's it, no holes for the grease to go anywhere. Help solve this mystery, I'm confused... ![]() Bob
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
Re: No grease going into upper A-arm shafts
You are right no place for the grease to go. 2 ideas. One the shaft warm up from driving the grease liquifies and oozes out along the threads. The other theory is if you give someone a grease fitting even though it does not do anything it gives them a warm fuzzy feeling that something good is happening.
Shake and Bake!
![]() Join Date: Feb 2010
I get about a half squirt in the zerk fitting then it won't take any more.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" |
I'm having the exact same problem. Just did an ECE 3.5/5 drop and replaced all of my bushings and cross shafts and now I can't get any grease into the zerks. I did take one out and it looked as if it were hitting the cross shaft inside the bushing. But even the ones that are not hitting won't take any grease. So frustrating! Im ready to drive my truck and 8 grease fitting are stopping me. If anyone has any suggestions let me know please. Wanting to get my truck redy for Memorial weekend. Anyone ever heard of a grease needle? Someone suggested that. Please help!!!!
"The Ultimate Sleeper" 69' SWB, Holley EFI 525 ci. BB, TH350, 3.73 Eaton posi/Moser axles, 1350 diveshaft, Vintec's 20"x8.5" and 20"x12", OPP windows, CPP rear coilover conversion |
I don't see the point of putting grease just inside the big nut. What good is that doing anyway?
On some of my originals that take grease, I see the grease oozing out from the rubber part. Now that makes sense to me. ![]() Still confused....
I'm guessing that the grease is supposed to lube the threads of the nut and cross shaft so its not just dry metal to dry metal. But I'm no mechanic. Would be nice to get an answer to this brain teaser.
My truck is still not moving! Somebody chime in with a solution.
Come on. I know someone else has encontered this problem?
![]() Join Date: Jul 2009
I just put my new cross shafts in but I haven't tried to grease them yet. Now I have something else to worry about
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
#9 | |
Same problem here. I hope that once my Panel is all back together and after a few miles on it things might loosen up a bit. Either that, or I convert over to the later model bushings as soon as mine wear out from no grease.
![]() Quote:
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
Sounds like the large nut with the zerk fitting is tightened to tight, and bottomed out against the cross shaft? Inside of nut is against the cross shaft, not allowing grease to enter? Was the arm easy to move before attaching the spindle? Did mine, and had it to tight, and the upper and lower a-arms would barely move. Backed off the nut about 1/8-1/4 turn. Free movement, and greasing was no problem. Hope this helps?
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
