Old 04-29-2010, 10:12 PM   #1
iluvmy72
Are wheel spacers dangerous?
Hey everyone....have a delima....my 96 3/4 ton burb my wife drives has some dodge rims rubbing on the upper ball joint carrier(I think that's what it is called)...it isn't much....just over a 1/4 inch....I got some 1/4 inch spacers from a off road shop today. He said put 2 on each side and as long as each bolt had at least a 1/2 inch in length I should be fine especially since it is 8 lug and not much off roading is done. But I have heard this is dangerous to do. Think I will be ok?
iluvmy72 is offline   Reply With Quote
Old 04-29-2010, 10:40 PM   #2
USSkoval
Re: Are wheel spacers dangerous?
No, not a good idea. I personally do not think it is a good idea to run slide-on type spacers in the front, but rear is OK. Definitely don't stack them.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 04-30-2010, 12:17 AM   #3
Smith's Customs
ya I would not run two slide on spacers. there are a few places that make ones that bolt on the hub and then the wheels onto that. those are very safe. I run them on my yota. they are spendy about 100 each. But you do see people run the slide on style at the drag strip all day long.
Smith's Customs is offline   Reply With Quote
Old 04-30-2010, 02:11 PM   #4
blazin
i was going to put them on the back of my blazer and desided not to. the shop wont do it unless i sign papers. they said they lock tight them on 3 times. do it let it dry, do it again and so on. as much as i would love to push my rear wheels out a few inchs.. i would be affaid a wheel would pop off and with a 6 inch lift , that wouldnt end to good.
blazin is offline   Reply With Quote
