04-30-2010, 08:43 AM | #1 |
Local Redneck Authority
Any input would be great on my cab.
I am thinking just fabbing some custom supports and closing up the holes in this cab, maybe stripping the bondo from the roof and re-sealing it. I need to pull the door opening back together as there is about 1" gap on the driver's side. Is this worth the work to make it nice again, or should I just look for a better cab to do some body work on some day? Like I've mentioned, this is more a funtion than looks vehicle right now but some day I'd like to make it look as nice as it performs.
04-30-2010, 09:08 AM | #2 |
Burnouts are therapeutic
Re: Any input would be great on my cab.
look for another cab that thing is going to be a bear to fix in my opinion
1969 CHEVELLE SS 1972 C10 ALMOST DAILY DRIVER 1968 C10 RUSTBUCKET (MISSION IMPOSSIBLE) 1972 PONTIAC LEMANS CONVERTIBLE (WIFE'S CAR) "My wife and I were happy for twenty years. Then we met." - Rodney Dangerfield "The difference between genius and stupidity is that genius has its limits." - Einstein |
04-30-2010, 09:14 AM | #3 |
that cab is missing a lot of metal. i would have to agree with red, you will spend too much time and money to get that cab all fixed up.
im surprised you havent fallen through the floorboard when you get in and sit down. well at least you know that your emergency brake will always work if your primary brake ever fails. just stick your foot through the hole and do a flintstones stop.
View pics of my truck - 1968 Chevy C10 SWB - Photobucket I'm not wasting money on my truck, I'm helping to rescue the economy one mod at a time.
04-30-2010, 10:01 AM | #4 |
Thanks for confirming my thoughts!
The flintstones stop won't really work when the cab is 35" off the ground, but I'm thinking the 2x4 with some old tire tread nailed to the end like a go kart might work. |
04-30-2010, 10:19 AM | #5 |
PROJECT 7DEUCE
Come to oregon there are cabs all over the place.... That one there is missing way to much material..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
04-30-2010, 11:29 AM | #6 |
Member #1049
I think the cancer on that one is "terminal"
04-30-2010, 11:33 AM | #7 |
please tell me that the tow strap is not holding the cab to the frame.
what caused all the rust in the first place? road salt, sitting in a field, or did you pour battery acid all over it.
04-30-2010, 11:53 AM | #8 |
Moderator
That looks like it was pulled up from the bottom of the ocean. I would look for another one.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
04-30-2010, 01:35 PM | #9 |
You'd need a whole new cab just to get enough patch panels for that one!
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
04-30-2010, 08:44 PM | #10 |
I've never seen that much rust on a vehicle in my entire life.
04-30-2010, 08:49 PM | #11 |
Honestly, I thought mine was in pretty bad shape, wow that's pretty bad! I have to agree with everyone else.
05-01-2010, 04:42 PM | #12 |
Well I'm glad I can make everyone feel better about their own projects! That's a typical Michigan old truck... I think next spring we'll take a road trip to Vegas and see what we can find on the way back... I have been looking on the OK and LV Craigslist postings and can't believe how cheap complete trucks are in those parts. For instance, in Michigan I found a stripped cab that was workable for $300. I have seen complete trucks minus the engine only for $250-650 depending on the shape of the trucks. For the money even in the small parts, I'll take the trip for the nearly complete truck.
05-01-2010, 04:44 PM | #13 | |
It sat under a tree in a field for something like 15 years... |
05-01-2010, 05:06 PM | #14 | |
Moderator
05-03-2010, 02:16 PM | #15 |
PM sent. I have a couple decent cabs.
2008 Chevy HHR 1/2 panel. 1949 Chevy Panel truck(just sittin, waiting) Board member #6 |
