Old 02-10-2003, 03:37 PM   #1
frisky68
Correct voltage meter wiring question
I have an Autometer Voltage gauge to put in my dash...my question is what is the correct wiring of this ??
Does the - terminal on the guage go to the positive side of the battery ??
and then what about the + terminal ?? does this go to the alternator ?? and if so which wire on the alt. ??
thanks for any and all help.
94 K1500 SWB w/ 4" body and suspension lift
frisky68 is offline   Reply With Quote
Old 02-10-2003, 03:44 PM   #2
72CustomCamper
If the Auto Meter wiring is anything like the VDO guages I recently put in my '72, you should have three wires/posts.
One goes to any 12 Volt source but preferably one downstream of your ignition switch.
The other is a ground.
The third is most likely for a small light in the guage. Splice this to your dash wiring.
Hope this helps a little!
'72 GMC C20, "2500 Super Custom", Custom Camper, New 454
'93 K2500 Suburban, Old 454 (157K)
72CustomCamper is offline   Reply With Quote
Old 02-10-2003, 09:49 PM   #3
Blue Beard
Blue Beard's Avatar
Last time I was on the Autometer site they had the instructions for this item.......
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 02-11-2003, 12:37 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Positive goes to the fuse block. If you hook it to your batery, it will slowly kill the charge...just like leaving the dome light on...maybe a little les of a load.
The neg needs to go to a good ground...a clean spot under a bolt on your dash should work.
