Old 04-30-2010, 02:36 PM   #1
67-1sttimer
67-1sttimer's Avatar
Help with rearend identification
Hi guys, im trying to find out the specs of the 12 bolt rearend i removed from my 67 chevy c10 1/2ton swb. Here what i see on it:
HA 09 01 W (on the pside axle shaft)
3896838 ( on the diff housing)
Any ideas what i have or where i can look up these #'s. Thanks, Chris.
67-1sttimer is offline   Reply With Quote
Old 04-30-2010, 04:14 PM   #2
burb71
Active Member
Re: Help with rearend identification
If you remove the rear inspection cover you should have a code stamped on the edge of the ring gear, one is a date code, the other is a tooth count, 1 for the ring and 1 for the pinion, if you divide the 2 numbers, this will give you the rear end ratio.
I cant remember how to read the codes that you found on the axle housing.
burb71 is offline   Reply With Quote
Old 04-30-2010, 04:19 PM   #3
john
member #16
john's Avatar
HA is a 3:73.1 ratio . The only way to tell for sure in a forty year old truck is to pull the cover and look. The HA code shows in several yr. model trucks including 1967.
john is offline   Reply With Quote
Old 04-30-2010, 04:42 PM   #4
cdowns
cdowns's Avatar
b4 pulling cover have a drain pan also a spray can of brake cleaner , a new gasket and 2quarts of reargear lube
