Old 04-30-2010, 04:45 PM   #1
twostiks
Brake Line Routing
I'm coverting my 69 3/4 ton from front drum to disc. I bought a 10pc Brake Line Kit for a 71 3/4 ton from inline tube. It looks like a big pile of spaghetti to me. I have the lines for the prop valve and the front to rear long line figured out. Does someone have a pic or diagram of how to route the rest of the lines on the truck? Thanks
69 3/4 Ton GMC CamperSpecial
99 Suburban 2500
twostiks is offline   Reply With Quote
Old 04-30-2010, 06:02 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Brake Line Routing
The problem,... is that your 69 (and all 67-70 trucks) will route the steel lines on the back side of the front cross,e,ber.
The 71-72 trucks route the steel lines to the front side of the crossmember.
This will require a metal tab to secure the line where it connects to the rubber brake line.
You should be able to cut and remove the original tab,... or fabricate a new one.
I'll see it I have any pics.
Keith
Convert to disc brakes.
Old 04-30-2010, 06:10 PM   #3
lolife99
lolife99's Avatar
Here's a couple of the passenger side of a '71.
Sorry,... that's all I have.
Keith
