2 Steering Wheel Questions
First question is which steering wheel is best for viewing a standard set of gauges when installed. The 67-68 three spoke or the 69-72 two spoke? Also, are they the same diameter?
It seems as though the 67-68 have thinner spokes and might be better but the 69-72 has fewer spokes so I can't figure out which one would block my view of the gauges less. Thanks for any help you can give. Last edited by ubtripn; 04-30-2010 at 05:56 PM. |
Who's got steelies?
![]() Join Date: Feb 2006
Re: 2 Steering Wheel Questions
I think the 67-68 3 spoke is better for viewing the guages. The thick spokes of the 69-72 are basically right in the way to read the guages unless you're making a turn.
![]() ![]() ![]() ![]() ![]() ![]() How to add a trip odometer to your 67-72 stock speedometer How to rebuild your Q-Jet My Truck Page My Youtube Channel |
Moderator
![]() Join Date: May 2007
I have OEM wheels on both my 72 trucks and have no problem seeing the gauges
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Thanks to both of you. On your two trucks, which steering wheel has the larger diameter? Or are they the same?
Grandpa in the rustmobile...
I like the look of the 3 spokes..
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Who's got steelies?
I've never actually measured them, but what I've read says the 67-68 wheel is 16.5" across, while the 69-72 wheel is slightly oval and 17.5" x 17" in diameter. I really like the look of the 67-68 wheel in my truck, and like the thin rim better. The 69-72 wheel in my burb has a slightly thicker rim, though not much.
I've noticed too that its easier to find a 67-68 wheel in good condition. Sure, it will have cracks, and these wheels were painted instead of being made of colored plastic, but is seems they just crack, the plastic doesn't start falling off with big missing chunks like the 69-72 wheels.
Who's got steelies?
Forgot to mention that the 40-60 series trucks used the 67-68 wheel all 6 years, but they were 18" in diameter, and starting in 69 they started making them out of the same colored plastic that always breaks off.
Right on, thanks everyone. I think the drivers height is probably a variable too when it comes to obstruction. I am going to go with a 67-68 three spoke. Then I will wrap it in leather. Thanks for the feedback everyone.
