Old 04-30-2010, 07:08 PM   #1
djmachinist
djmachinist's Avatar
Is my Steering Crossbar Center link on backwards?
I'm having some steering issues....The Steering is a little nervous when driving at freeway speeds and the turning radius is pretty poor. In addition the inside wheel in a tight turn at steering lock is dragging the tire or scrubbing the tire a lot. you can actually feel the tire dragging. I jacked the front end up to see if I could see anything wrong with the Steering linkage. I think the Center link is flipped 180 deg. I have attached pics:.....
Thanks,
Dale
1969 GMC SWB FLEETSIDE
ZZ 383 CRATE MOTOR,700R4,& 3.73 POSI & VINTAGE AIR
DALE JONES
MY BUILD THREAD: "69 GMC SHORT FLEET"
http://67-72chevytrucks.com/vboard/s...d.php?t=388447
djmachinist is offline   Reply With Quote
Old 04-30-2010, 07:23 PM   #2
NINERS1
NINERS1's Avatar
Re: Is my Steering Crossbar Center link on backwards?
Yes it is, when fliped it will run real close to your crossmember, also your tie rods go in from the back and the nuts go on the front, not sure if it matters. you can see the tierod in this pic
71 chevy cheyenne lwb
http://s321.photobucket.com/albums/n..._tab_my_albums
Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote!
NINERS1 is offline   Reply With Quote
Old 04-30-2010, 07:34 PM   #3
djmachinist
Niners1,
Thanks for the excellent pic, Now I know for sure. I'll take it back to the shop tommorrow and have them fix it and re-align the front end.
Dale
DALE JONES
Old 04-30-2010, 07:39 PM   #4
NINERS1
NINERS1's Avatar
your welcome, dont ask how i know
Old 04-30-2010, 07:41 PM   #5
djmachinist
Originally Posted by djmachinist View Post
Niners1,
Dale
Niners1,
Oh...It does matter if the tierods are on the front or back. If they are located in the front that increases the akerman angle by quite a bit. That would explain why the inside wheel is turning to much at steering lock causing severe tire scrub.
Thanks again,
Dale
DALE JONES
Old 04-30-2010, 07:45 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
You will have to remove it and swap it "end for end".
Easy to make this mistake,... when replacing everything.
You might have to put some 90 degree grease zerks in the inner tie rods also.
(makes it alot easier to grease the inners)
Keith
Convert to disc brakes.
Old 05-01-2010, 03:54 PM   #7
djmachinist
Well....I took the truck to my shop that did the suspension and brake rebuild and ask them to flip the centerlink that was in backwards....Wow!!!what difference!!! The truck has lost the nervous twitch and low speed steering lock is ok now. The steering radius is improved quite a bit. one more problem fixed!...
Dale
DALE JONES
Old 05-01-2010, 07:26 PM   #8
NINERS1
NINERS1's Avatar
DJ, I know what you mean, just recently built my front end and it drives sweeeeet!!!
Old 05-01-2010, 11:58 PM   #9
OhOneWS6
OhOneWS6's Avatar
That upper bump stop is on the wrong side of the A arm?
OhOneWS6 is offline   Reply With Quote
Old 10-18-2017, 09:04 PM   #10
RedRider
RedRider's Avatar
This thread assured me that I didn't accidentally flip the center link, but now I'm having a hard time getting to the grease zerk on the inner tie rod:
Maybe it's just a matter of getting an angled grease gun fitting in there (I only have the straight-end). How do you guys typically get to that zerk?
RedRider is offline   Reply With Quote
Old 10-18-2017, 09:46 PM   #11
S-31
90° zerk fitting will take care of that
S-31 is offline   Reply With Quote
Old 10-18-2017, 10:47 PM   #12
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The inner tie rods I bought from Moog came with 90 degree zerk fittings.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 10-19-2017, 05:01 PM   #13
RedRider
RedRider's Avatar
Thanks guys, a 90 degree fitting would've made more sense in that spot. This is a CPP front-end kit so the tie-rod ends are likely not Moog. I'll try finding a 90 degree grease gun fitting instead.
