Old 04-30-2010, 08:19 PM   #1
D-Rat
D-Rat's Avatar
window regulator question
my driver door is developing a 'catch' on the windo regulator...almost like a flat spot or something on the rotating assembly making the window go up hard every time the crank passes that spot each revolution.
Is this an easy fix or are my entire regulators shot? I haven't had the door apart, but remember a nylon rotating wheel that rolled inside the regulator track on an old Ford car I used to have...the wheel went to crap and it cost about $2 to fix....hoping it's that simple here.
1970 CST with a screaming 400
www.nissan4wheelers.com
D-Rat is offline   Reply With Quote
Old 05-03-2010, 09:42 PM   #2
gonzo6869
Cops, ha, catch me if you can!
gonzo6869's Avatar
Re: window regulator question
I just got done doing my drivers side window this weekend. The regulator itself is not that expensive, about $40.00. To install, it is not as difficult as I thought it would be (I have never done one before). I say get a new regulator and go from there, I am almost sure that is your problem. If you do go that route and need help with the install, let me know and I will walk you through it.
72 C-10 Stepper
350/TH350
3.73 in the back
Edelbrock intake and Carb
Hooker Comp Headers
275/60R15 on Rallies
gonzo6869 is offline   Reply With Quote
