Old 05-01-2010, 01:38 AM   #1
orange66fleet
Lowered in Cleveland
bellcrank stud for z-bar
need some advice, I am in the middle of swapping the engine in the 66, from a 307 to 350. all was well untill I tried to screw in the bellcrank stud for the z-bar into the engine, stripped. what are my options to make this screw in tight, so I never have to worry about the stud coming out. thanks
orange66fleet is offline   Reply With Quote
Old 05-01-2010, 05:29 AM   #2
LILRED66
LILRED66's Avatar
Re: bellcrank stud for z-bar
Helicoil...here is a link:
http://www.helicoil.in/helicoil.htm
You can also:
1. Drill & tap to next larger size...cut and weld new threaded end on ball stud to fit new hole size.
2. Infill the hole with a TIG weld, drill and tap to original size.
3. Use some of the epoxy compounds on the ball stud, to securely fasten it into the factory threaded hole in the block.
Good luck and let us know how things turn out.
LILRED66 is offline   Reply With Quote
Old 05-01-2010, 08:26 AM   #3
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
here's a good epoxy-based compound:
http://jbweld.net/products/jbweld.php
Larry
fleetsidelarry is offline   Reply With Quote
Old 05-01-2010, 04:17 PM   #4
Captainfab
60-66 Nut
I would go with the Helicoil. I'm not a fan of epoxy/JBweld for things like this.
Old 05-01-2010, 04:32 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
I'm a fervent advocate for JB Weld, but not for something like a clutch pivot that is going to be exposed to enormous torsional forces over a long period of time. I'd also vote for the Helicoil or welded repair.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-02-2010, 03:31 AM   #6
blackedoutharley
On mine I did both... installed the Helicoil and then JB weld on the stud threads... its in there for good.
blackedoutharley is offline   Reply With Quote
