Old 05-01-2010, 12:55 PM   #1
blazin
all over the road.. still
i have a 72 blazer ive restored. new everything. since the day i bought it and drove it home its been all over the road. so i bought a rebuilt steering box, ball joints, 6 inch lift, everything to tryin make it steer good. the damn thing wonders all over the road. cant figure it out. i know it will never drive like a new truck but it should be this bad. i had a 1980 and it drove alot better then this thing. ive spent so much money on this thing and im ready to give up. i'd like to just put the body on a newer yukon or blazer frame suspension.. but i dont have the skills for that. any ideas on what could be wrong?
blazin is offline   Reply With Quote
Old 05-01-2010, 01:11 PM   #2
blazin
lifted and all over the raod??
Old 05-01-2010, 01:59 PM   #3
Erl
Erl's Avatar
Re: lifted and all over the raod??
Could be the type of tires.
1968 GMC 305 V6 3/4 4x4 Stepside
06 Corvette Daily Driver
Dallas TX
Erl is offline   Reply With Quote
Old 05-01-2010, 02:25 PM   #4
72lb4x4
Re: all over the road.. still
Have you had it aligned? I think if the toe is off it'll wander. Maybe a list of what's been replaced/done would be more informative than everything...
72lb4x4 is offline   Reply With Quote
Old 05-01-2010, 02:33 PM   #5
sdailey
The Few, The Proud
sdailey's Avatar
It sounds like you have bump steer. Did you install an extended drop pitman arm when you installed the 6" lift? If not, then more than likely that's the cause of your steering issues.
Shannon
sdailey is offline   Reply With Quote
Old 05-01-2010, 05:44 PM   #6
blazin
yup its been aligned, everything is new.. steering box is rebuilt, everything down from that is new. everything up from the steering box is old. leafs, bushings, you name it.
Old 05-01-2010, 05:50 PM   #7
blazin
bump steer on a 6 inch lift? yup a dropped pitman arm. came with the skyjacker kit. all new leafs front and back. bushings, ball joints, steering box is rebuilt. old rag joint and steering column, all new everything joint that part of the suspension. maybe i need a crossover steering? rag joint? steering column? i dont know but im about 30 grand in and its driving me nuts
Old 05-01-2010, 05:59 PM   #8
mixermike
mixermike's Avatar
did you install a steering stabilizer(dampner)? i assume with a 6 inch lift your runnin big tires.
mixermike is offline   Reply With Quote
Old 05-01-2010, 07:54 PM   #9
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
I posted this same response to your question in the suspension forum as well.
x2 Thats what I was thinking as well!
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 05-02-2010, 12:04 AM   #10
project67-stepside
project67-stepside's Avatar
definetly need a stabilizer, or the camber is out of wack, my dodge did the same thing until i adjusted the camber
project67-stepside is offline   Reply With Quote
Old 05-02-2010, 07:46 AM   #11
LONGHAIR
MERGED.....Please don't do this, it just makes for confusion, besides the fact that it is against the rules.
XIV. Multiple Posting - It is simply not acceptable to post your question more than once, or to post it in more than one forum. Choose the forum that your question or post best fits in, and place it there and only there. If, after posting, you feel it should be in another forum, private message the forum Moderator and ask if they would move it for you.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 05-02-2010, 10:54 AM   #12
blazin
i have a stabilizer, its aligned.. maybe it could be the bump steer or tires. i bought some new toyo open countrys.. i hope that does the trick. if not i guess i will do cross over steering setup. if that dont work... i burn it.
Old 05-02-2010, 11:48 AM   #13
onlyifihadachevy
Did you change the tie rods, you said everything but them. If you did is the frame cracked, or the steering box loose? I know you said you changed them but there is a chance that you didn't tighten it enough, or missed the crakced frame.
72 gmc 2500 2wd drive convert
My 72 thread
http://67-72chevytrucks.com/vboard/s...d.php?t=346712
THe other truck, wheeler 69 1/2 4x4, yellow and rusty.
http://67-72chevytrucks.com/vboard/s...d.php?t=350300
onlyifihadachevy is offline   Reply With Quote
Old 05-02-2010, 11:52 AM   #14
blazin
yes i changed the tie rods. i will check and see if the box is loose. where would the frame be cracked? by the steering box?
Old 05-02-2010, 11:56 AM   #15
blazin
steering box is tight.. could it be the rag joint? i havent replaced that yet. i was going to do that when i get a new steering column
Old 05-02-2010, 12:01 PM   #16
martindc1
How wide are your tires? Did a shop do the alignement? If so, do you still have the spec sheet? Toe out will make it wander.
Currently truckless, previous trucks:
67 K20, 87 K10 aka V10 & 72 C10
martindc1 is offline   Reply With Quote
Old 05-02-2010, 12:05 PM   #17
blazin
the tires that are on the blazer are interco, trxus,33-12.50-18R.. they are square looking. the top tread is flat across, not raised in the middle like most. yes a shop did the alignement. i dont have the spec sheet.
Old 05-02-2010, 12:27 PM   #18
martindc1
Those are pretty wide, if you are driving on roads with slight "ruts", it will cause it to wander.
Old 05-02-2010, 12:41 PM   #19
LONGHAIR
I would take it to another shop and specifically ask them about "caster". Wandering is usually a caster issue.
Tell them that it wanders all over the place....they should have a solution.
Old 05-02-2010, 01:20 PM   #20
mod58
Do you have a degree shim under the front springs?If so how many degree's is it?If you take to much caster out with say with a 8 degree shim it will wander or if you have toe out it will do the same.
mod58 is offline   Reply With Quote
