![]() Join Date: Jan 2007
6.0L Engine Parts
I have a few parts left over from an engine swap I just did. First off I have a power steering pump with the bracket for a hydroboost setup. The one line was bent a little bit, but could easily be bent back. I can include the pressure side line with it or without it. $35 plus shipping.
Next I have a camshaft with the lifters out of an LQ9 6.0L engine with very low miles on it. It does not come with the cam gear that is on it in the picture. It came out of an engine that had been dropped and the block was broke (its a shame too...) Anyways, $45 plus shipping. Last I have the heads off the same LQ9 engine. The one head is broken but comes as a pair. I dont have a picture of them right now, except when they were still on the engine. Also, when the engine was dropped, the exhaust manifold was still on the engine and it ripped it right off the head. $40 plus shipping. Last edited by Redden05; 05-01-2010 at 01:24 PM. Reason: price for heads added |
Re: 6.0L Engine Parts
Pictures of the broken block and heads:
![]() Join Date: Nov 2008
PM sent.
I figured someone would at least be interested in the camshaft...
camshaft would make a cool lamp if nothing else!
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap |
I just paid $100 for a power steering pump and brackets
![]() Last edited by Jim_PA; 05-04-2010 at 12:08 PM. |
And... in pic #1 -- the lines coming off the block -- are those for a factory engine oil cooler?
And can I safely eliminate that on mine? If so, how? |
Yea those lines are for a factory engine cooler. Yes you can take it off. Some of the cars had a block off plate instead of the cooler. I know the camaros had a plate that was threaded to put a oil pressure sender on it. Hope this helps!
NOTE: I used a camaro 'block off plate' from the GM dealer but did not get the bolts and reused the stock ones, which are TOO long you will want to get the bolts OR several washers, or cut the long ones....
might want the PS, still got it?
1979 c30 3+3 dually 1946 GMC |
Truck and auto performance nut
Yes....my LY6 has a cover plate there.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
