Old 05-01-2010, 03:56 PM   #1
nikwho
nikwho's Avatar
cleaning up the engine compartment in my '83
Well, I just picked up this old truck. Its got a 305 in it and it will probably stay there untill my '59 project is finished. I'll probably drop a fresh 350 in it when I have time. I have an edlebrock alum. intake, 600cfm carb, chrome air cleaner and valve covers to shine it up and wake up the engine. I am also replacing the stock exhaust manifolds with some headers. I can use all of this stuff when I drop a 350 in it at a later date.
My question is, how do I get rid of all of the emissions equipment? I didn't want to just start ripping everything out and end up pulling anything that I would want or need. Where I live, there is no smog regulations. I'd like to keep all of the stuff just in case I ever end up needing to smog it. There is a canister attached to the radiator support on the drivers side that a lot of the smog stuff connects too. Can that entire unit be pulled out?
nikwho is offline   Reply With Quote
Old 05-01-2010, 03:58 PM   #2
nikwho
nikwho's Avatar
Re: cleaning up the engine compartment in my '83
I also have no intention of using the a/c. I want to pull it, but again retain the ability to re connect it at a later date. Essentially, I'd like to get rid of everything that I dont need, just to make it look as clean and un-cluttered as possible.
Old 05-01-2010, 08:22 PM   #3
73chevyman
73chevyman's Avatar
if it were me I get rid of everything but the canister it does help with the gassy smell... thats the only thing i would keep
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 05-01-2010, 11:20 PM   #4
nikwho
nikwho's Avatar
So, literally just start pulling all of the wires out and plug any hoses or what not that are left? What stays connected to the canister? What is its purpose? Thanks, Nik
Old 05-01-2010, 11:39 PM   #5
1974ChevyC10
Overworked and Underlaid
1974ChevyC10's Avatar
As far as removing your emissions stuff ive done this myself on a 78 chevy so what they have should be somewhat similar.i took off the EGR valve and emissions carb swapped out the carb with a non-emissions carb and used an egr block off plate for the EGR,put small pipe plugs into the exhaust manifolds where the AIR tubes threaded into,removed the cats and used some straight pipes and mufflers i had already as the exhaust system,unhooked the charcoal canister from the engine,re-did some vaccuum lines and other assorted items i cannot recall now as it has been several years since i last did this.if you want in the next couple weeks ill be back in town so if you like you can bring it by my dad's pad and i can help guide you in what needs removed and on top of that we can hang out,grill up some food and just shoot the breeze and show off our respective trucks and talk all things automotive.
I'd rather push a Chevy than drive a Ford
The Beast-1978 C10 LWB
Red-1978 C10 LWB
(Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012
Gone but will never be forgotten-RIP
(Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012
Taken from us to soon but you will live on in our hearts-RIP
1974ChevyC10 is offline   Reply With Quote
Old 05-02-2010, 11:16 AM   #6
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
powerdriver 1958 is offline   Reply With Quote
Old 05-02-2010, 11:42 AM   #7
nikwho
nikwho's Avatar
sorry! It won't happen again.
