should i get it?..'64 2wd/4wd conv.lifted
ok i would like to know if a 1964 longbed c10 converted to 4x4 with a 6 inch lift,that needs wheels and tires,and a motor and body work and some interior and whatever and maybe 1 window is worth 500$?
i have a chance for one,but idk if this is worth it?i know to me personally it is,id jsut like to get opinions
1969 Shortbed in progress 1982 short step, few suspension and motor upgrades.getting a 468 1978 Shortbed fleet side bonanza fully loaded 1978 k20 Silverado loaded.currently engine-less 1989 k10 suburban 9" lift 65 nova And more |
1961 crewcab
Re: should i get it?..'64 2wd/4wd conv.lifted
I would say yes, most 60-66's in that price range are at least worth that much in parts and scrap.
if you want it and can afford to fix it up yes.. pics would hepl though-
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
IMO it would depend on what kind of job was done in the conversion. Was it done right or is it a hack job......
Redneck Hillbilly
I agree with Captain Fab, as long as the conversion work is at least solid then I would go for it. If it was a hack job install you could spend a lot more time and frustraion trying to make it right than you might want to.
But we do need pics... |
