02-10-2003, 05:37 PM | #1 |
New Headers
I got my new coated headers on this weekend.
Bill Durham http://home.attbi.com/~bulldurham 72 Cheyenne Restoration in progress Currently: frame sand blasted and powdercoated, Inline Tube brake and fuel lines, Blazer tank in rear, Holley Red electronic fuel pump, Eaton posi with 3.42 gears, 2 1/2" drop front spindles, 4" drop rear springs with adjustable panhard bar, KYB shocks, ZZ 502/502 GM Performance crate engine, Zoops brackets and pulleys, Vintage Air, dual electric fans, Ram Air II hood and late model sport side bed. |
02-10-2003, 05:39 PM | #2 |
Pic 2
02-10-2003, 05:43 PM | #3 |
hey, now thats an engine. Looks great.
Two questions, What make are those headers and what size tubes do they have? I am always on the look out for any information I can get on a BB in these trucks as I am building a 454 for mine. Once again, that looks great. Keep us updated on this one please. S ____________________________ Size does matter, get a BB! |
02-10-2003, 05:44 PM | #4 |
Pic 3
02-10-2003, 05:47 PM | #5 |
I went with the Flowtechs with 1 3/4" primary tubes. You have to grind off some of the flange on the underside of the header to get them to fit over the head bolts on the 502.
02-10-2003, 05:55 PM | #6 |
Post Whore
That looks awesome!
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
02-10-2003, 06:03 PM | #7 |
Almost Satisfied
That looks great! I have a couple questions for ya since you are setting yours up very close to what I have in mind for mine.
1. Did you use 72 BB stands? If not, what did you use? 2. Did you buy your chrome alt/ac from Zoops as well? 3. Who's product did you use for your fans? I'll be saving these pics for motivation to save the big bucks for the ZZ502!!
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021. "I can't complain, but sometimes I still do. Life's been good to me so far." |
02-10-2003, 08:05 PM | #8 |
The stands are from a 71 with the 5 piece mounts. The alt is from zoops and the AC is from Vintage Air. The fans are Flex-a-lite.
02-10-2003, 08:14 PM | #9 |
14.1 @ 96MPH
What tranny is that?
Project1970 - LS1 Swap Complete! |
02-10-2003, 08:33 PM | #10 |
What is the difference from the '71 big block engine mounts to the '72?
Just starting my BBC project and need to get as much info as possible. Thanks.
'72 GMC custom camper 350/350 |
02-10-2003, 11:35 PM | #11 |
Project - The tranny is a built TH 350
Wheels - Below is a pic of the towers. The one on the left is pre 72 and the one on the right is a 72. The pre 72 towers are cheap but the mounts are expensive. The 72s are expensive and stronger but the mounts can be purchased at any parts house.
02-11-2003, 05:08 AM | #12 |
Hi 72 Chevy: That is beautiful !!!! I have a stupid question, do the 502 crate motors come with aluminum heads and what kind of valves (stainless)? and is your block aluminum also? I don't know that much about them, thanks Doug
02-11-2003, 08:19 AM | #13 |
The ZZ502 comes with aluminum heads and cast iron block. The valves are 2.25" stainless steel on the intake side and 1.88" on the exaust side.
02-11-2003, 08:34 AM | #14 |
67-72 Addict!
Very nice!, Bet ya can't wait to take that bad boy for a spin!!!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
02-11-2003, 10:46 AM | #15 |
Senior Moment
Next ? Does your engine set back farther with the BB and did you have to shorten your drive shaft ?
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
02-11-2003, 12:39 PM | #16 |
I want to do the same to mine .It's going to cost about $2,500 to rebuild the origional 402 and I was wondering How much has the project cost so far if you don't mine me asking. so I can compare the price difference. Thak you
02-11-2003, 01:09 PM | #17 |
Almost Satisfied
I can't speak for 72Chevy on his cost, but you are looking at about 10 grand worth of stuff there in those pics alone. A new ZZ502 is around $7200....add the great things he has like the chrome alt/ac/pulleys, fans, built TH350 and it doesn't take long to add up.
02-11-2003, 03:03 PM | #18 |
70c10 - You are righ about that, I can't wait to just get it started much less drive it.
1970 CST Short Wide - The engine does set back about an inch. I had the shaft shortened and moved the tranny support. 72'BBGMCSGCC - 1971Stepside is about right with the 10 grand cost. I have not sat down and totaled everything up yet. I'm almost afraid to at this point. Everything is new except for the frame which I had blasted and powdercoated and the steering box which was new last year. The 502 was on special through GM in November for $6800 and the Zoops pulleys and brackets with power steering pump and remote tank was around $800. I figure I will end up with around $20,000 plus by the time it is finished. If everything goes as planned I will have it at the Chevy/GMC Truck Nationals in Pigeon Forge the first weekend in May.
02-11-2003, 03:49 PM | #19 |
Almost Satisfied
Yeah, don't total the receipts up until after you are driving it again!! LOL
02-11-2003, 07:10 PM | #20 |
Senior Moment
When you say you moved the tranny support did you have to drill new holes or where they alrweady there?
02-11-2003, 09:03 PM | #21 |
I drilled new holes in the crossmember.
