Old 05-01-2010, 05:37 PM   #1
brans72
Do you need to change plugs when converting to HEI?
I was just curious if you can use the same plugs (part #) in a 250l when converting to HEI or do you need to change them out? What plugs would you recomm if I want to change them out? Thanks Brandon
brans72 is offline   Reply With Quote
Old 05-01-2010, 05:43 PM   #2
vectorit
What?
vectorit's Avatar
Re: Do you need to change plugs when converting to HEI?
I'd just re gap them, since the electronic ignitions require a bigger gap most of the time.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 05-01-2010, 05:48 PM   #3
leddzepp
Moderator
leddzepp's Avatar
IIRC, it is .050
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 05-01-2010, 06:36 PM   #4
lks dcvn
lks dcvn's Avatar
.045 plug gap for HEI is recommended.
lks dcvn is offline   Reply With Quote
Old 05-01-2010, 08:49 PM   #5
brans72
so just regap old plugs to .045?
Old 05-01-2010, 09:50 PM   #6
Leviticus
Shake and Bake!
Leviticus's Avatar
Yep, but there is never a bad time for new plugs
"All tyranny needs to gain a foothold is for people of good conscience to remain silent."
Thomas Jefferson
"You are remembered for the rules you break."
General Douglas MacArthur
"Support Our Troops And The NRA"
Leviticus is offline   Reply With Quote
Old 05-01-2010, 10:43 PM   #7
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yup, same plugs, .035 with points, .045 with HEI.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 05-01-2010, 10:52 PM   #8
theslawdawg
theslawdawg's Avatar
I concur. I just changed mine over to HEI. I could have used my old plugs, but used the opportunity to put new ones in (along with new plug wires). I just made sure I adjusted the gaps.
1972 Chevy C10
theslawdawg is offline   Reply With Quote
Old 05-02-2010, 08:29 AM   #9
brans72
Thank you fellows!
Old 05-02-2010, 11:33 PM   #10
RustyDan
RustyDan's Avatar
I agree. .050 gap.
Cleaned up my HEI. Confirmed 12v power source. Cleaned up contacts. New cover.
Tried to clean/gap plugs till one broke in half.!@#$%^ What was I thinking?
NEW PLUGS man. Runs sweet. (here wife...take it for a test drive..she made it back).
Darn...juskiddn
"Do not follow where the path may lead.
Go instead where there is no path and leave a trail."
"SEMPER FI"
Never retired-Always a Marine
'72 C10 Longhorn-very daily
'86 C10 Van (mothballed)
previous; '65 C10 shorty
& bunches of M/C's
RustyDan is offline   Reply With Quote
