Old 05-01-2010, 06:47 PM   #1
SanitysBane
Dual Diaphragm Boosters
Hey guys,
I have an '87 K5 Blazer with a big block and I am wanting to run a dual diaphragm booster to gain a little more clearance around the valve cover, does anyone make a kit for this or who makes a universal booster?
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 05-01-2010, 10:10 PM   #2
8mpg
8mpg's Avatar
Re: Dual Diaphragm Boosters
80's and 90's S10 is supposed to have a dual diaphragm. CaptFab or something like that on the board sells conversion brackets.
8mpg is offline   Reply With Quote
Old 05-02-2010, 12:16 AM   #3
Captainfab
60-66 Nut
The '82-'87 S10's had dual diaphram boosters, but you would have to do some work to get one to mount up to your Blazer since the two mount a little differently. Have you considered going with a hydroboost? You'd get better braking and lots of valve cover clearance. Plus you could use a factory hydroboost set up that would be a bolt on.
Old 05-02-2010, 04:08 AM   #4
SanitysBane
The only problem with the factory hydro-boost is the cost...I have tried rebuilt hydro's and they all seem to fail around 3 months but the GM new hydro is big money this is why I am looking at a dual diaphragm booster...
'88 K5 Blazer
