Old 05-01-2010, 07:02 PM   #1
seafoam68
seafoam68's Avatar
exhalst manifold help
O.K. guys, something happened to me today that has never before. About a month ago I removed a 350 from my 1980 c-30. did machine work, reinstalled today. The problem is the pass. side manifold will not bolt back up to the head. I can start the rear four bolts, but not the front two. Or the front four but not the rear two. I pulled it off the truck and tried to mount it to a spare engine and the same thing. It is as if the front or rear ports of the manifold has pulled toward each other. Anybody heard of this or come across it? Wandering if I can apply heat and a big hammer to "strech" it back out?
seafoam68 is offline   Reply With Quote
Old 05-01-2010, 07:52 PM   #2
3r!c84
Badass
3r!c84's Avatar
Re: exhalst manifold help
the manifold has worped
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 05-01-2010, 08:33 PM   #3
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Time for headers!!
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 05-01-2010, 10:28 PM   #4
80SPORT
80SPORT's Avatar
There is a tool available to spread the manifold or use a porta power ....very common problem on chevy small block....
80SPORT is offline   Reply With Quote
Old 05-01-2010, 10:32 PM   #5
80SPORT
80SPORT's Avatar
Lisle 13000 is the tool ...$6.91 on amazon ...or at your local parts store
Old 05-01-2010, 10:32 PM   #6
54Caddy
GM Addicted
54Caddy's Avatar
go down to napa and ask them for an exhaust manifold spreader. You put it in btween the two gaps and tighten it. As you tighten it it pushes on the manifold and spreads it so that you can install the bolts. This is a very common problem. What happens is that the manifolds get hot then you unbolt them and sit and metal has the tendency to move. The tool is about 12 bucks man, get on it and put them suckers on and fire that beast up! Good luck man.
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 05-01-2010, 11:47 PM   #7
seafoam68
seafoam68's Avatar
Thanks guys, never had this problem before. I guess I always worked with the old ramshorn manifolds or headers. Thanks again !
