Old 05-01-2010, 08:23 PM   #1
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Air leaking out of MC causing brakelight to come on
I have air comming out of the hole (all the way thru MC). I can cover it wiht my fingers to seal it up. It used to not come out of this hole. It causes my brakelight to come on, and brakes to be really hard to push down. What do I do to fix it and why is it doing it? Thanks!
John
1999 Toyota Tacoma 4x4
Old 05-01-2010, 08:26 PM   #2
Boog
laying low
Boog's Avatar
Re: Air leaking out of MC causing brakelight to come on
Your brake booster has gone bad. Replacement is necessary.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 05-01-2010, 08:36 PM   #3
oldblue1968chevy
Really?!
crap, oh well it IS 40 years old
John
Old 05-02-2010, 05:24 AM   #4
mclairmo
Bad booster, Autozone has replacements for about $100.
mclairmo is offline   Reply With Quote
Old 05-02-2010, 09:09 AM   #5
cdowns
cdowns's Avatar
a leak is a bad booster but i think theres additional problem with master cylinder causing the light to go on // i'd change both and while at it go over the whole brake system to tune it up to specs// the factory service manual has excellent info on the proper procedure to bleed the brakes for proper operation
Old 05-02-2010, 11:38 AM   #6
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
There is a rubber seal that fits over the rod that pushes the master cly.and and fills the recess in the booster,Is that missing? Noticed fresh paint on the booster and i'm wondering if its pinched or fell out?
If you go the rebuilt/new booster don't be surprised if the master cylinder comes with it .Some re-builders won't sell one with out the other
powerdriver 1958 is offline   Reply With Quote
Old 05-02-2010, 09:45 PM   #7
oldblue1968chevy
its a new MC, i just put new paint on the booster to make it look better.. I'll check it out tomorow after school...whats this seal look like.
I pretty much dont have power brakes on the truck, theres a little but they dont help much
John
Old 05-02-2010, 10:23 PM   #8
oldblue1968chevy
so I need a new booster?
should I go with the gold finish or painted one?......
John
Old 05-04-2010, 10:32 PM   #9
oldblue1968chevy
Can I rebuild it? Dad was thinking I could rebuild it for cheaper, if you can get parts even..
John
