Old 05-01-2010, 08:51 PM   #1
kev2809
low n' slo
kev2809's Avatar
Extra port on my tank
hey guys. i was wondering what i should do with my extra port? i want to add a schraeder valve to it, or maybe a coupling for an air hose, or drain?
just wondering what i would get most use out of/and what everyone else is doing. thanks for any input!
edit - forgot to add my tank is an 8 port tank. 4 for the valves, 1 on top for my tank gauge, 1 on the side for the pressure switch, and 1 on the other side for the compressor. bottom one is empty
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 05-01-2010, 09:18 PM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Extra port on my tank
Why not do both?
Hart_Rod is offline   Reply With Quote
Old 05-02-2010, 01:08 AM   #3
kev2809
low n' slo
kev2809's Avatar
didn't even think of that! I may run a t with a schraeder and coupler on the end...
-_--_--_ _________
Old 05-02-2010, 01:12 AM   #4
1971gmcshortbed
1971gmcshortbed's Avatar
/raises hand. What would you use the shrader valve for?
1971gmcshortbed is offline   Reply With Quote
Old 05-02-2010, 01:41 AM   #5
Hart_Rod
Hart_Rod's Avatar
If your compressor goes out, you could manually add air to your tank......
Old 05-02-2010, 10:37 AM   #6
kev2809
low n' slo
kev2809's Avatar
beat me to it... so a drain port is not that important?
-_--_--_ _________
Old 05-02-2010, 11:07 AM   #7
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I always just use the coupler to full the tank. I have a fitting that is male on both ends and just hook the air hose straight up to it if I need air while I'm working in the shop.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 05-21-2010, 12:26 AM   #8
kev2809
low n' slo
kev2809's Avatar
well I want the schroeder (sp) valve in case my compressor poops and I can fill my tank at a gas station or wherever.
I was browsing around ***************** and I'm having a hard time finding the right fittings lol. Ace didn't help at all, so I'm just gonna order them, I need airline anyways. what would I need to run a setup like harg robs, of course the cheapest easiest way possible!
-_--_--_ _________
Old 05-21-2010, 06:49 AM   #9
kev2809
low n' slo
kev2809's Avatar
I think I got it.....
I got 1 3/8" brass tee, 1/2" - 3/8" forged elbow (for tee to tank), and 2 1/4" - 3/8" reducing bushings (for schroeder valve and coupler).
-_--_--_ _________
Old 05-21-2010, 09:11 AM   #10
weekendracer728
weekendracer728's Avatar
I would put a drain in there too!!!
weekendracer728 is offline   Reply With Quote
Old 05-21-2010, 09:22 AM   #11
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
^^^ agreed %100
you would be surprized how much water these wil get in them from condinsation....
I put the drain in the bottom and put a 90* on the top with a piece of hoes running the a hole in the back of the frame that has a shrader and a snap fitting it makes it easy to fill and the location is easy if I have to use the air in the tank to fill something.....I use the same tech as Smashing Chuck when I'm around the shop working on it I plug into the shop compressor
another good idea it s to use shut offs on each line if you have a line failure it doesn't blead off all the air in the tank (you can shut off the bad line) I didn't do this but when I fix the line I plan to add them for a few $$ its worth it ( ask me how I know??) I beleive that you can't have to many fail safes exspecially it it only cost a few $$
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 05-21-2010, 09:39 AM   #12
dznucks
dznucks's Avatar
I have two 3 gallon tanks. I put a schrader on each tank, in the port that was point straight down for both the reasons mentioned here. drainage and compressor pooping out.
I also put a coupler on an extra port. but then when i got to thinking about it, it sure is going to be wild unhooking an air line with 175 psi in it.
dznucks is offline   Reply With Quote
