05-01-2010, 09:27 PM | #1 |
Front Brake Caliper Stuck
Well driving the blazer today I started to fill a pull. Well by the time I got home the passenger side was nice and hot. I tried squeezing with channel locks and bleeder open, but no movement.
I am currently trying to let a little WD free it up. Any tricks? Its a 4wd with the dana 40. |
05-01-2010, 09:36 PM | #2 | |
Re: Front Brake Caliper Stuck
Edit: Oh, you mean to get it off, . You'll probably have to use a c-clamp to push the piston in far enough to get the caliper off.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 Last edited by Hart_Rod; 05-01-2010 at 09:37 PM. |
05-01-2010, 09:37 PM | #3 |
05-01-2010, 10:59 PM | #4 |
its all about the +6 inches
they are so cheap, she wont even notice the funds missing.
05-01-2010, 11:31 PM | #5 |
check the rubber brake line also.I have had 2 that started deteriorating on the inside and when you mashed the pedal it would force fluid by but when you let off the pedal the fluid could not back up.this will also cause the caliper to stay locked.
05-01-2010, 11:38 PM | #6 |
If the bleeder was open would this still be the case? with bleeder open I can't get it too open up. Also I am unable to get it to close at all. I am certain with it off it should close more.
05-02-2010, 11:36 AM | #7 |
shove a large screwdriver or prybar into the slotted hole in the top of the caliper, and pull it outwards. this will give you the leverage you need to get the piston to move in a little bit.
05-02-2010, 11:39 AM | #8 |
Yeah I got it off and can not get the piston to go back in.I have tried using a big c clamp and also some really big channel locks. I am pretty certain I need a new one.
05-02-2010, 12:04 PM | #9 | |
Where I live rusted /plugged bleeder screws is common.
1967 Suburban 292 3spd 1964 Chevy II wagon 1971 Monte Carlo 402BB 1964 Cadillac series 62 2dr 1964 Bonneville 2dr/ht 1967 GTO 1978 Chevy Van 30 1989 R30 Crew Dually Bonus Cab |
05-02-2010, 09:01 PM | #10 |
I will seconed what "67/72junkie " said. When i change a caliper i also change the brake hose, you cannot see inside the hose to see if the hose is damaged. good luck
