05-01-2010, 10:23 PM | #1 |
Mudtrap problem
Hey all,
I have a problem with my mudtrap in my truck (i think thats what its called). It the very front right of my truck and it seems that water is pooling in it and causing it to rust from the inside out...I drilled a hole to let water escape but it still seems to find a way in there and makes a nice little rust mud that i have to claw out every once and a while. any suggestions would be great Matt |
05-01-2010, 10:56 PM | #2 |
its all about the +6 inches
Re: Mudtrap problem
what is the mudtrap?
05-01-2010, 10:58 PM | #3 |
What?
Re: Mudtrap problem
Pictures?
Chris 1968 K20 Suburban 1972 K10 LWB PU |
05-01-2010, 11:11 PM | #4 |
Re: Mudtrap problem
Sorry chaps...i was told thats what it is called but i was obviously mistaken
Here is a pic Its on the inside of where i circled Matt |
05-01-2010, 11:49 PM | #5 |
GMC with Blue Plaid
Re: Mudtrap problem
Just keep it clean. Flush it out every time you wash it. Coating it on the inside with a good rust paint will help. I would think by drilling a hole in it may worsen your rust problem.
Current: 1972 GMC Super Custom 1500 402 < 73K Orig MI 2015 GMC Canyon SLT(Daily Driver) Previous: 2008 Chevrolet Colorado LT 2.9L I4 1988 Chevrolet Suburban Silverado 10 350 < 60K Orig MI 1984 GMC S-15 2.8L V6 1976 GMC Sierra Classic 2500 Camper Special 350 1980 GMC High Sierra 3500 Dually 350 4spd 1974 Chevrolet Cheyenne Super 10 Shorty 454 (Was my Dads, I wish I still had it) 1969 GMC 910 250 I6 4spd |
05-02-2010, 01:41 AM | #6 |
Active Member
Re: Mudtrap problem
A factory Fender has what is called a "Weep Slit" built in the cup and also in other places on the truck to let water drain out.
I dont know if the reproduction Fenders have this or not. Somtimes the Weep Slit can get pluged up from road debris, I just had this happen on my pass side door, on a day after a heavy rain, I opend the door to get somthing and when I closed the door it closed better than ever with a nice heavy & solid thud but I also heard the sound of water sloshing around in it. So to let the water drain I just slid a Knife up into the slit and opened it right up. |
05-02-2010, 07:55 AM | #7 |
I am a Referee of life.
Re: Mudtrap problem
The door slits are bad about this also.I cleaned mine every time I washed then realized if I replaced the window seals and fuzzies the water couldn't get in.The fender cups always seem to collect water and the passenger side has the added battery drip problem.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
