early/late cab interchangibility questions...
i tried searching but couldnt really find what i was lookin for so i figured i'd ask.
i know to do the bbw swap the proper way to take the interior panel out of the donor as well as the window then trim your outter to match after you install it... will the inner panel out of a 64-65 (flat front window) work on a 60? the cabs look the same to me it just looks like they changed the front half but not the back...just wanted to make sure it'd work before i spend any cash thanks in advance, sorry if this has been posted and i just didnt see it searching |
1961 crewcab
Re: early/late cab interchangibility questions...
yes the rear interior panel fits 60 through 66 chev and gmc.
also check out the link in the faqs section there is a great how to on the process.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 Last edited by jonzcustomshop; 05-02-2010 at 07:26 AM. |
