05-02-2010, 02:39 PM | #1 |
fiber-optic cable
can someone explain the install of the fiber-optic cable for the shift indicator. this is on my 1972 tilt column. thank you
05-02-2010, 02:43 PM | #2 |
Moderator
Re: fiber-optic cable
Tilt columns do not use the fiber optic cable. There is a gray wire that leads to the shift indicator, and a bulb fits in the housing.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
05-02-2010, 04:00 PM | #3 |
thanks for the reply. is the gray wire in the column already? does the bulb plug in somewhere? thanks
05-02-2010, 04:06 PM | #4 |
Moderator
The gray wire should be there...it is separate from the turn signal harness, and goes all the way up into the shift indicator housing. The other end plugs into the fuse panel. There is a socket on the end of it that holds a small bulb (I forget the size, but it is readily available at parts stores) When you remove the 2 screws on top of the column to get the indicator housing off, you should see the socket/bulb sitting right there beneath it. Hopefully it is not missing
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 05-02-2010 at 04:07 PM. |
05-02-2010, 04:12 PM | #5 |
Moderator
Note: When you remove the housing be VERY careful not to break the shift indicator pointer. I made that mistake once...
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 05-02-2010 at 04:12 PM. |
05-02-2010, 05:26 PM | #6 |
member #16
The grey light wire plugs on the cluster feed terminal in the fuse panel. It will dim with the dash lights.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
05-02-2010, 06:19 PM | #7 |
thanks again for the reply. i am a little confused about this shift indicator. there is no pointer by the letters. on the collar that moves with the shift lever there is a little hood like maybe a light would go in there and shine up onto the indicator??? thanks again
05-02-2010, 06:21 PM | #8 | |
Moderator
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 05-02-2010 at 06:27 PM. |
05-02-2010, 07:45 PM | #9 |
well, there is no place for a light bulb under the shift indicator!!! this column came from a 1972 GMC and it is a tilt. would that be different than Chevy? thanks
05-02-2010, 07:50 PM | #10 |
Moderator
No, they are the same. Sounds to me like it is missing also. Is there a gray wire sticking out along with the turn signal harness? If not, it is probably missing.
05-02-2010, 07:57 PM | #11 |
Moderator
Here is what you should see:
And here is an oooold thread with a lot of info: http://67-72chevytrucks.com/vboard/s...d.php?t=307100
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 05-02-2010 at 07:58 PM. |
