Old 05-02-2010, 04:21 PM   #1
ACII
Airbag mounted directly on the 4link arms ??
HEllo together,
after i have installed my triangulated 4link suspension .....
i have a problem to locate the bags.....first of all i wanted to install the bags directly on the axle tubes ....
but with this solution i have the problem with space for the exhaust...
What do think about the solution to install the bags directly on the lower 4link bars ....
for example with this brackets:
http://gravity-werx.com/bagonbarmounts.aspx
So far i am not sure if this solution causes to much pressure on the lower bars and the ball joints and so on ???
Hope you can help me out ??
achim
ACII is offline   Reply With Quote
Old 05-02-2010, 05:03 PM   #2
dv8customs
dv8customs's Avatar
Re: Airbag mounted directly on the 4link arms ??
No problems mounting the bags to the lower 4-link bars but depending on the size of the bar it may be necessary to add a gusset.
dv8customs is offline   Reply With Quote
Old 05-04-2010, 05:27 AM   #3
andrewmp6
And exhaust depends on how low you want the truck.If you want to lay frame good luck with full exhaust most do turn downs in front of the rear end.
andrewmp6 is offline   Reply With Quote
