Old 05-02-2010, 06:33 PM   #1
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
64-66 spotlight
not mine, Ebay 110525446392
Old 05-02-2010, 07:02 PM   #2
jbgroby
jbgroby's Avatar
Re: 64-66 spotlight
You got to wonder where in hell thats been hiding over the past 45 or so years. Has the bushing and templete too.
jbgroby is offline   Reply With Quote
Old 05-02-2010, 07:11 PM   #3
aerotruk63
aerotruk63's Avatar
Re: 64-66 spotlight
All the NOS stuff is a mystery. Before I pass, I hope to have all my finds installed. Had a friend who worked for his small town GM dealer all his life. I bought etiquette tags to label what the used stuff was, he passed before we had a chance to. His wife sold off stuff by the trailer load. She crushed all the cars and trucks in the back 40. I'll have to drop by and see what's left.
Old 05-02-2010, 07:24 PM   #4
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: 64-66 spotlight
do these spots have an inner bracket? I see the one for the outside, does the inside just get plugged with that rubber groumet?
****BTW!! I'm calling dibs on this one, so no one else bid on it ok?****
Old 05-02-2010, 07:30 PM   #5
aerotruk63
aerotruk63's Avatar
Re: 64-66 spotlight
This is a unity bracket therefore it should have the universal interior bracket. the 60-63 had special GM furnished brackets ( not supplied by Unity, cast by Autolite) inside and out. I have no literature for the 64-66 though I have a couple of unity brackets like in the picture. Unity #187L. Should ask him for a photocopy of the template though.
Old 05-02-2010, 07:39 PM   #6
jonzcustomshop
1961 crewcab
Re: 64-66 spotlight
I could probably make a template from the hole in my truck.
thats actually all I need is the bracket, I have 3-4 unity spots, but they have the roof -top of it - style bracket.
do you have a pic of the universal interior bracket?
is that unity #187l still available from unity?
Old 05-02-2010, 07:51 PM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
Re: 64-66 spotlight
On typical Unity spotlight installations not having the truck specific inside bracket, there is an angled rubber spacer that slides against the inside windshield post (or window frame or where ever the shaft enters the car), followed by a ring clamp that is in held in place by a set screw. In the picture below, the clamp is at 12:00, the rubber spacer is at 3:00, the ring at 6:00 has a loop that retains the wire after it leaves the handle, and the L shaped bracket at 9:00 is used to ground and anchor the spotlight shaft. The short end goes inside the square portion of the clamp against the spotlight shaft.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-02-2010, 07:51 PM   #8
aerotruk63
aerotruk63's Avatar
Re: 64-66 spotlight
http://unityusa.com/SearchResult.aspx?CategoryID=5 Skips after 184 to 189. Would you like the brackets that I have? The roof mount brackets would have the same interior brackets as what you need for the pillar mount. Do you have the exterior brackets?
Old 05-02-2010, 08:01 PM   #9
aerotruk63
aerotruk63's Avatar
Re: 64-66 spotlight
Very interesting, no kit in the application search for 60-63 Chevrolet conventional trucks at Unity http://unityusa.com/application_search.asp
