3/4 ton body mounts.
I ordered a set of 1/2 ton body mounts for my 67. I noticed the part number was for the 3/4 ton. Does anyone know if there is a differance between the two? Thanks
Moderator
![]() Join Date: May 2007
Re: 3/4 ton body mounts.
Yup....the rear cab mounts are much thicker on 3/4 ton trucks.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
do I need to get the 1/2 ton mounts then? Are they taller or just wider? thanks again
its all about the +6 inches
is your truck is a 1/2 ton 2 wheel drive, then you need the 1/2 ton mounts.
If your truck is a 4x4, then you need to 3/4 ton ones. |
ok thanks I will just send them back and get the right ones
