Old 05-02-2010, 08:39 PM   #1
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
Can a brake booster be tested without starting the vehicle?
I have a hand vaccum pump tester thing and i attached it to the booster and pumped it up to 20 and stopped, the booster held the vaccum for 30 min without leaking before i unhooked it.
Is there anything else that can go wrong with a booster except for leaking to make it bad?
1967 C10 swb
1970 GMC Jimmy 4x4
2005 Chevy tahoe Z71
2001 Chevy impala
bcj67chevy is offline   Reply With Quote
Old 05-02-2010, 08:49 PM   #2
69halfton
69halfton's Avatar
Re: Can a brake booster be tested without starting the vehicle?
is the booster on a truck right now thats not running? or you just have the booster sitting on your work bench at home?
usually if it holds vacuum it should be good, I'm no expert but i know there isn't much too them, just a diaphram and a one way check valve on the vacuum port, and the steel piece that the push-rod that moves the pistons in the master cyl....
- Jason
If you can turn, Youre not going fast enough.
Favorite caption:
first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around..
..back when men were men.
69halfton is offline   Reply With Quote
Old 05-02-2010, 09:34 PM   #3
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
still mounted on truck.
1967 C10 swb
1970 GMC Jimmy 4x4
2001 Chevy impala
Old 05-02-2010, 09:40 PM   #4
hayhauler71
hayhauler71's Avatar
If it holds vacuum its good
hayhauler71 is offline   Reply With Quote
Old 05-02-2010, 09:59 PM   #5
Leviticus
Shake and Bake!
Leviticus's Avatar
Get a big Slurpy straw and stick it in the hole and suck away, it it holds pressure its good Just kidding, if you have a vacuum tester and can hook it to the port somehow, and it holds the vacuum it should be fine.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent."
Thomas Jefferson
"You are remembered for the rules you break."
General Douglas MacArthur
"Support Our Troops And The NRA"
Leviticus is offline   Reply With Quote
