Old 05-02-2010, 09:35 PM   #1
dbaillargeon
New at this
Hello everyone I started restoring a 1969 GMC
C 30 is only 2wd but it has the smaller 16.5 tires that are 8 bolt. I would like to change the stance a little, being it's a one ton. Any suggestions with regards to size and style as well as where to get them. I was also wondering about some colors it's in primer right now. We have come to the conclusion of either red or black but open to
suggestions. Thanks for all and any information.
It's a pleasure to be in this with everyone.
dbaillargeon is offline   Reply With Quote
Old 05-03-2010, 06:27 AM   #2
dwaite72lnghrn
Re: New at this
Welcome to the board. I am assuming it is single rear wheel being it is 16.5 rims! I am running Firestone Transforce 9.50rx16.5 tires. You could pickup some 16" wheels with the 6.5" 8 bolt with a 4 3/4" center which would give you more choices in tires.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 05-03-2010, 11:14 PM   #3
dbaillargeon
Re: New at this
Thank you dwaite72lnghrn
Have you had much experience with the 1969 GMC? I have a five dollar question for you......I removed the accelerator pedal and dimmer switch. When I tried to removed the accelerator pedal bolts that attach to the floor both of them broke. They look like a dome shaped shoulder bolt the back of the pedal snaps over to keep it to the floor pan. Would you know where I could pick up a set. So much for just removing the pan quickly and replacing it. Thanks to all.
Old 05-17-2010, 08:42 AM   #4
dbaillargeon
Re: New at this
Help!!!!
I'm having an issue with my 1966 GMV 305 V6. It starts great when it's
cold after it warms up (like are shutting it off at the
autoparts store). It want to crank for a long time before it will start you have to flutter the gas and then hold it to the floor. Thanks for any help!
A lot to think about, not much to worry about...
Old 05-17-2010, 08:54 AM   #5
Shyguy
Junior Member
Shyguy's Avatar
Re: New at this
Welcome to the forum from Southeast Missouri.
If your are talking about the two little bolts with a ball type on the end the the bottom of the accelerator pedal mounts on to some site vendors have them. I have seen them in the LMC catalog. I will have to be buying some when I replace the floor pan.
Have you checked your choke to see if it is sticking shut or mis-adjusted?
Also the float may be sticking causing the engine to flood.
Danny
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 05-17-2010, 11:04 AM   #6
lovnthe70
lovnthe70's Avatar
Re: New at this
show some pics!!
1970 GMC- 454
DONT GIVE ME NO JIBBA JABBA!!!
lovnthe70 is offline   Reply With Quote
Old 05-17-2010, 09:54 PM   #7
dbaillargeon
As Request PICS!!!!
I am new at this so bare with me. This is my 69 GMC 1 ton Longhorn
Old 05-17-2010, 09:59 PM   #8
jamie72
jamie72's Avatar
Re: New at this
welcome nice start... btw did the tow hooks come on there from the factory??
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 05-17-2010, 10:08 PM   #9
NORMSCOLORADO
NORMSCOLORADO's Avatar
Re: New at this
hey man def do away with the 16.5s get some standard 16's once i get enough money up im goin with a set of white wagon wheels.... they are cheap and look good.... as for color black is not a good color for the long beds mine was black before i went to green!
playing with photoshop and bagged it lol
oh and i was up your way with the 67 yesterday! I had to go out to st regis falls to give my condolences to the truck po's wife.... he passed on the 6th... hella nice guy! then we cruzed out to malone to see if the yard on rt11 was open.... then back through lyon mtn back home! 170 miles on the old girl! lol
04 Chevy Colorado Z71 4X4
76 Chevy C-10 Custom Deluxe (sold)
67 Chevy C-30 1 Ton 9' stepper 6.5 Turbo Diesel
NORMSCOLORADO is offline   Reply With Quote
Old 05-18-2010, 08:25 PM   #10
dbaillargeon
1969 GMC C 30 Longhorn Stepside - New Exhaust
Good evening everyone
Had a great day withthe truck. Got the exhaust all finished and it looks and sounds great!!!!!! Thanks to my mechanic.
Old 06-06-2010, 09:45 PM   #11
dbaillargeon
Re: New at this
Can anyone help? I have a 1966 305 V-6 in my 1969 GMC C30, I am having an terrible time with the Stomberg 23-235 that is on it. I am going to upgrade the Carb, I think I would like to put a Edelbrock 1404 or Holley 4412c. I realize I will need and adapter plate. Any Help would be greatly appreciated.
THANK YOU ALL
Old 07-11-2010, 09:51 AM   #12
dbaillargeon
Smile Re: New at this
I am excite just landed another whole truck. I hope it will move along the restoration. I just order the paint - wish me luck
Old 07-11-2010, 01:24 PM   #13
LockDoc
The Older Generation
LockDoc's Avatar
Re: New at this
Looks like you are getting some work done on the truck. I can't really help with the carb problem but if you could find another carb to try or just have that one rebuilt it would probably be cheaper. Ask at your local auto parts store if they know of someone that rebuilds carbs.
Keep up the good work...
LockDoc
Leon
Old 01-14-2011, 01:27 AM   #14
dbaillargeon
Re: New at this
Hello Everyone,
Been awhile since I have been able to post....I would like to ask for a little help. I have a 1969 GMC 1-ton pickup, the box has been changed. The pictures I have posted show it has a step side, but the box is about 6" short near the cab. I have been reading about the longhorns. What were the criteria for a longhorn in '69? Did GMC make a Longhorn? Just need some help figuring my truck out....Thank you
Old 01-14-2011, 11:22 PM   #15
LockDoc
LockDoc's Avatar
Re: New at this
Yes, they had a longhorn but they didn't call it that. If your 1 ton started out as a cab & chassis truck it should have a 133" wheelbase. If that is the case I think the longhorn fleetside bed or the 9 ft. stepside bed are the only ones that will fit it and I am not 100% sure about the 9 ft. stepside bed.
LockDoc
Leon
Old 04-16-2011, 11:29 AM   #16
dbaillargeon
Re: New at this
Hello everyone,
I should post pictures later. Just sent the cab to be painted.....yeahhhh! Great feeling. One problem. The box is junk . But the wonderful woman I am married to said go to Carlise at the end of the month and find on for it. Did I mention she is a wonderful woman... Any suggestions where to start down there, area, vendors past experience. Thank again for any or all help
Old 04-16-2011, 11:34 AM   #17
NORMSCOLORADO
Re: New at this
That awesome man! i really need to go down there one of these days..... just got my foot inthe door at a awesome body shop.. so het some changes saved up and off i go! lol
norm
Old 04-16-2011, 11:37 AM   #18
NORMSCOLORADO
Re: New at this
ohhh are you gunna leve the 8' step on it or you gunna go back with a 9'?
Old 04-18-2011, 10:21 PM   #19
dbaillargeon
69 gmc
No, looking for a 9' box, wish me luck.....Anyone give me an idea where to start in Carlise PA?
Old 06-03-2011, 11:03 PM   #20
dbaillargeon
Re: New at this
Help!!!
I have my cab finished, I found the cab lights we a newer style, someone just put on to cover the hold in the cab. The cab has the raised platforms for each of the five lights. I don't mind upgrading them to an LED, the original were the "hockey puck" style. Has anyone upgraded to LED or able to buy all the lights again?
Any help would be greatly appreciated....????
Thanks again
Old 06-03-2011, 11:23 PM   #21
71swb4x4
71swb4x4's Avatar
Re: New at this
Start a new thread for each problem you have, you will get a much better response by putting a proper title on the thread so someone that is interested in that particular subject see it (cab lights for instance). I am not trying to be a jerk, just trying to help. There are a lot of people on this board, and each one knows something about something, but not many know something about everything.
Post a thread titled something like Need help with cab light style for my 69 C30, or something similar. You should get a better response.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
1969 gmc c 30
