trailing arm bushing
I have taken off trailing arms on my 65 swb stepper and have ordered new bushings. How do I get the old rubber ones out?
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: trailing arm bushing
I believe they have a steel sleeve and they will need to be pressed out or a BFH might do it too
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
Senior Enthusiast
I'm going to be putting new rubber bushings in mine this summer and previously asked for advice. I'm going to follow a suggestion from Lakeroadster - use a small bit and drill the rubber out between the inner and outer shells, then remove the outer shell either with a hammer or press. One recommendation I read was to split the end of the shell, and then peel it in toward the center until it falls free.
The open end of the trailing arm must be supported to keep it from collapsing or being distorted. I'm going to use a piece of large pipe cut to the length of the trailing arm width, then remove about 40% of one side so I can slip it over the bushing. This is essentially what the factory tool looks like in the shop manual. Another option is burning out the rubber, and most recommend doing it outside over a bucket of water. Burning rubber is nasty, and very difficult to extinguish especially if it falls and sticks to something it shouldn't.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 |
Thanks all for the info. I ordered the Polyurethane bushings from classic parts, so I need the steel housing.
http://www.classicparts.com/1960-72-...ctinfo/74-876/ by the way is firmly rusted in place. I used a screw driver and dug out most of the rubber then I grabbed the inner metal tube with a vice grip and twisted it out. Then I removed the remaining rubber. For all this effort, I hope the new bushings work. Last edited by Ynotnow817; 05-03-2010 at 01:44 PM. |
Yes, as posted above, use a drill and drill a bunch of holes, then BFH or burn it out with a torch. It takes some time, but technically is easy.
The outer steel sleeve stays in the trailing arm...DO NOT bugger it up or press it out. Your new poly bushings will slide right in that outer sleeve.
292 + TKO500 |
Thanks Heater
Drill worked great.
#8 | |
Senior Enthusiast
Here's an earlier thread that discusses the squeaking and other issues:
http://67-72chevytrucks.com/vboard/s...g+arm+bushings
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502 Last edited by markeb01; 05-04-2010 at 12:16 PM. |
thanks mark.
