Old 05-03-2010, 03:20 PM   #1
Mertz
Can't do a burn out.
I have my 72 Chevy truck 350 set up with the Qjet all dialed in and get great accelleration. I tried powerbraking it and doing a full throttle takeoff and it launches rather slow and then once it gets going it goes great. At one point I had it standing on its wheels but I haven't been able to reproduce that since. I don't have the 350 trans kick down installed and I have a stall converter set up for towing. 2500 if I remember correctly. I can do a nice burnout if I am turning when I take off with or without the power brake. It just seems like it doesn't have much power as I hit full throttle but as I get going I hear the secondaries working. 50 to 70 takes just a few seconds without the secondaries. The truck does not have a posi. I am not sure what my rearend is but think it is a 3:08 or 3:28. I have a 1" 4 hole spacer on it to try to help with torque but it soesn't seem to help. Intake is a Edelbrock 2101 with ceramic headers and flow through exhaust.
Mertz is offline   Reply With Quote
Old 05-03-2010, 03:39 PM   #2
prostreetC-10
My Carbon Footprint
prostreetC-10's Avatar
Re: Can't do a burn out.
No fun when you can't do a burnout. Time for a BBC.
What is your initial timing set at? That can make a big difference.
prostreetC-10 is offline   Reply With Quote
Old 05-03-2010, 04:02 PM   #3
Mertz
Inital is at 12 with total around 50 mechanical and vacuum all in at 3000. Around 34 with mechanical no vacuum. MSD Ready to Run distributor.
Old 05-03-2010, 04:40 PM   #4
mclairmo
How tall are your tires?
mclairmo is offline   Reply With Quote
Old 05-03-2010, 04:56 PM   #5
Mertz
They are fairly tall 16" Uniroyal LTs
Old 05-03-2010, 05:20 PM   #6
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Probably not your problem, but these trucks do have pretty good rear brakes (at slow speeds). When I was driving my '70 the rears would lock long before the front.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 05-03-2010, 05:50 PM   #7
cdowns
cdowns's Avatar
if you go on a slight uphill incline and let the truck roll slowly back and rev the crap out the engine then just drop it in lo you might b able to burnout of course you might also pop the ujoints or crack the tranny case too
Old 05-03-2010, 07:15 PM   #8
'72customdeluxe
I have a new goodwrench 350 with a 2101 manifold, richened 1978 q-jet, and flowtech ceramic coated headers. I know my eBay hei has a VERY lazy mechanical advance curves, as did many factory smogger hei setups. A new advance spring and weight kit might help and is cheap. Your gears and tires aren't helping for sure. If your carb is lean you're not getting full power either
'72 cheyenne super step, '05 long bed gmc
'72customdeluxe is offline   Reply With Quote
Old 05-03-2010, 07:18 PM   #9
tim21391
tim21391's Avatar
are u running points? if so they might be shot i had a problem with this before i went to hei
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 05-03-2010, 08:22 PM   #10
'72customdeluxe
Says an msd hei. I guess my theory about his mech advance was wrong too, all in by 3000 sounds fine
Old 05-04-2010, 02:01 PM   #11
scott's69
WORTHLESS CRUISERS
scott's69's Avatar
Your stall convertor might be one reason. Too much convertor not enough motor would cause your problem.
Scott Hammond
Lancaster, SC
1969 Chevy2005 Chevy Silverado Z71 72 Chevy 1972 SWB 454
If you don't live for something, then you'll die for nothing. www.xclusive-images.com
scott's69 is offline   Reply With Quote
Old 05-04-2010, 05:46 PM   #12
tim21391
tim21391's Avatar
oh snap my bad i mustve missed that part.. maybe the coil went bad in it?
Old 05-04-2010, 05:50 PM   #13
Mertz
The ignition is working perfectly. I read some techniques for doing burnouts on line, like rolling backward and then hitting it or rolling forward slightly and then stomp on the gas and brake at the same time.
Old 05-04-2010, 06:30 PM   #14
BarryB
BarryB's Avatar
I had this problem once before, my advance inside the dist. was stuck, wasn't letting the timing to advance properly. double check it, even though its new.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 05-04-2010, 06:35 PM   #15
jholley
jholley's Avatar
I doubt it's a 3:28. Someone here can correct me if I'm wrong but I don't think they ever came with that gear and I've looked around I don't think you can even buy that gear for a Truck 12 bolt. 3:08, 3:42, 3:73, 4:11 are the most common. I had 3:73 gears in mine and could turn the tires just stomping on the go pedal. I mistakenly put 3:08 gears in it hoping for some mileage and it just killed the fun factor. My motor isn't anything special, 290hp 350 and TH350 tranny. I could power brake it with the 3:08 gears but that sucks. Ultimately I put the 3:73 gears back in. Is the diff open or a posi? If it's an open and you can't even turn one tire that sucks!
Jim
Garage fillers...
85 Chevy C10 Silverado LWB
07 Nissan Altima
2006 Mini Cooper S
jholley is offline   Reply With Quote
Old 05-05-2010, 11:22 AM   #16
Mertz
Its open. The mechanical advance is working fine. I tried rolling backwards a little yesterday and stomping it and I got it to let go for a short distance. I think the gears are probably 3:08 but I couldn't find anything on the build sheet. Is there a number somewhere to tell me what the gears are?
Old 05-05-2010, 02:48 PM   #17
BIGBLU 72
BIGBLU 72's Avatar
i doubt that having a 3.08 gear is the problem cause mine will lay about 10 foot of one wheel wonder rubber with no power break. Secondaries not kicking in a possiblity or not getting full throttle from accel linkage?
68 C10 LWB 2/4 drop 406/th400/3.73posi
04 Silverado SS LQ9 6.0/4L65e/4.11posi AWD
BIGBLU 72 is offline   Reply With Quote
Old 05-05-2010, 03:52 PM   #18
Mertz
I have been removing and replacing the carb to get the jets and rods right so I haven't verified that the linkage is allowing for full throttle but the secondaries are definitely kicking in once I get going. You can hear them a few feet down the road when it starts to take off. I also don't have the kickdown cable connected.
Old 05-05-2010, 05:46 PM   #19
prostreetC-10
My Carbon Footprint
It's a pretty funny post really. A guy begging for burnout help. It's not unheard of for a truck with hwy gears, tall tires and a tired motor not be able to do a burnout. Do you know for a fact it's a 350? 305 and 307's are dogs. Can you have someone lift up on the right rear part of the bumper??
Old 05-05-2010, 05:58 PM   #20
Rob H.
Rob H.'s Avatar
ProstreetC-10 Here's one of those 307 dogs!
Bonestock 307 three on the tree that had sat for 10 years!
Rob
72 C/10 (under reconstruction)(destruction ? LOL)
48 Willys CJ2A
1952 Super "A" Farmall (Grandfather's)
Rob H. is offline   Reply With Quote
Old 05-05-2010, 06:19 PM   #21
Mertz
The only reason I posted this was that I don't think I am getting full power out of my "350" with 1.5 roller tip rockers, Edelbrock 2101 manifold, ceramic coated headers with dual flow through exhaust and H pipe, rebuilt transmission with stall kit, timing at the optimal 36 initial + mech, MSD Ready to Run distributor, new Moroso spiral core wires and dailed in qjet (couldn't do it with the 1406 Edelbrock either). I think I should be at about 290 hp and should be able to break them loose. I have been trying to build low end torque and it would appear that I haven't been successful if I can't do a burnout from a standing start. I use the truck to pull a 5000 lb trailer and would like as much torque as I can get out of the 350.
Old 05-05-2010, 07:15 PM   #22
tasian
tasian's Avatar
check for a tag on the diff cover if theres nothing there you can always run the other numbers stamped on the rear end
what kind of top speed are you getting from it? 3:08's are pretty tall that may not be all of your problem but i doubt its helping much for your low end
Betsy's build
70 c20 4 speed 406sb
tasian is offline   Reply With Quote
Old 05-05-2010, 07:32 PM   #23
handsomerob
handsomerob's Avatar
Whats the stall on your converter? if your stall speed isn't matched with the torque curve of your engine your truck will be a dog.
handsomerob is offline   Reply With Quote
Old 05-05-2010, 07:32 PM   #24
Mertz
I have had the truck up to 85 without problems. I was afraid to go any faster on the road I was on but it seemed to be pretty close to all it had at the time of that test run with the carb adjustment I had. My acceloration from 50 and up is great. 50 to 70 seems like seconds but I haven't timed it.
I think it is 2500. It was new when the trans was rebuilt a few years ago. If it is 2500 or 2800 would that mean I would need to have all my timing in at 2500 or 2800 instead of 3000 like I have it now?
Old 05-05-2010, 07:57 PM   #25
prostreetC-10
My Carbon Footprint
YouTube- 72 C/10 Smokin' them after sitting for years!
LOL....oh, I know it can be done. This was my FIRST car from my loving parents in '84. Nice '69 Chevelle with a 307. I will not tell you what we had to do to get this much smoke. Yes I will: buddy lifts up on the back bumper.....i get 'er going....then he runs back and takes the pic. No sheet!
