05-03-2010, 06:05 PM | #1 |
"Hooked on Quack"
Lokar Pedals
I did the search and after looking through 415 pages of build threads and talk about shift linkage I am at a loss.
My 71 has NO gas bedal just the rod and so I figured hey I will stick a lokar pedal on there, well if I am gonna do that may as well update the the clutch pedal pad and brake pad. Only issue is so much of their stuff is universal I can't figure out what will fit and what will be $70 down the toilet. If anyone has some part numbers or advise on this it would be much appreciated.
Semper Fi, Kevin USMC |
05-03-2010, 08:47 PM | #2 |
PROJECT 7DEUCE
Re: Lokar Pedals
Id call em and tell em what ya got...
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-03-2010, 10:31 PM | #3 |
Re: Lokar Pedals
I went with this one and it worked out Lokar Pedal
Later I saw they made a version with a larger pedal. I wish I had seen it before I bought mine. I think the larger pedal looks better.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb |
05-04-2010, 09:20 AM | #4 |
"Hooked on Quack"
Re: Lokar Pedals
Yeah they have an XL version. I was thinking of doing a gas pedal like that and then the matching covers for the clutch and brake. Probably the best idea is to just call them, just curious what other have used from them.
05-04-2010, 09:33 AM | #5 |
PROJECT 7DEUCE
Re: Lokar Pedals
I have used the gas pedal from them that goes down threw the floor its a very truck piece.
05-04-2010, 10:46 AM | #6 |
Re: Lokar Pedals
Let us know what they say
05-04-2010, 11:32 AM | #7 |
Re: Lokar Pedals
^ X2 looking at going with lokar myself!
05-04-2010, 01:55 PM | #8 |
WORTHLESS CRUISERS
Re: Lokar Pedals
I have Lokar pedals. The XLs. I removed my old gas pedal assembly, installed their pedal assembly with their throttle cable and added brake pedal. Simple install.
Scott Hammond Lancaster, SC 1969 Chevy2005 Chevy Silverado Z71 72 Chevy 1972 SWB 454 If you don't live for something, then you'll die for nothing. www.xclusive-images.com |
05-04-2010, 01:57 PM | #9 |
Re: Lokar Pedals
could you let "us" know where you got them and what all you got...if ya dont mind?
05-04-2010, 02:10 PM | #10 |
WORTHLESS CRUISERS
Re: Lokar Pedals
Can't remember exactly where I got them but Jegs, Summit, Ebay all have Lokar stuff. Ive got a Lokar Billet Throttle pedal assembly(gas, brake, dimmer) firewall mounted with Lokar HiTech Universal braided stainless steel throttle cable. Hope this helps.
Scott Hammond Lancaster, SC 1969 Chevy2005 Chevy Silverado Z71 72 Chevy 1972 SWB 454 If you don't live for something, then you'll die for nothing. www.xclusive-images.com Last edited by scott's69; 05-04-2010 at 02:11 PM. |
05-04-2010, 02:45 PM | #11 |
Re: Lokar Pedals
We sell the full line of Lokar Products. Less than Summit and Jegs
05-04-2010, 02:51 PM | #12 |
chevy truck fan
Re: Lokar Pedals
mike,
would you be able to PM me what a package deal would be for the gas pedal, brake cover & dimmer switch if available? i would be very interested in the "XL"series. thanks!! |
05-04-2010, 06:48 PM | #13 |
"Hooked on Quack"
Re: Lokar Pedals
I pm'd Mike, I like summit and jegs but would much rather support a member of this board.
01-14-2011, 05:09 PM | #14 | |
Re: Lokar Pedals
Big_Mac ( )(_.)(._)( ) ( ) \___/ ( ) |
01-14-2011, 05:23 PM | #15 |
Re: Lokar Pedals
If you can hold out long enough, Lokar is developing direct bolt in gas pedal assemblies and matching brake and clutch pedal assemblies.
01-14-2011, 05:25 PM | #16 |
Re: Lokar Pedals
darn, i had already bought the set of the other ones too.
