Old 05-03-2010, 08:12 PM   #1
wyatt earp
can't figure it out
i have a 1986 Gmc truck. Bought it a little rough and have been changing minor problems. Just recently after i changed the thermostat housing it started to act up.
I have poor acceleration when going up hill. tonight it stalled itself out. It smells really rich. I can't figure out why it is doing this and why.
any help would be great.
wyatt earp is offline   Reply With Quote
Old 05-03-2010, 09:01 PM   #2
bitchin85
bitchin85's Avatar
Re: can't figure it out
thermostat housing shouldnt affect the way it runs unless u put the wront thermostat back in it and even that wouldnt be that dramatic of a differance.. get the carb rebuilt and go from there.. also just go aroung and look at your plugs and check your timing and go from there but my guess would for sure be carb problems.. whats on it now? stock quadrajet?
"I'll keep my guns, money, and freedom. You can keep the "change"
bitchin85 is offline   Reply With Quote
Old 05-03-2010, 09:52 PM   #3
lester622
if its a tbi im having the same problem and have no idea wat the hell is the problem
lester622 is offline   Reply With Quote
Old 05-03-2010, 09:57 PM   #4
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Yea there should be nothing that the t-stat or housing would have caused even with the wrong one. Sounds like a misfire with the plug wires or plugs maybe or the carb needs a good cleaning or rebuild. Might also check for any vacuum leaks you can find.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 05-03-2010, 10:00 PM   #5
bitchin85
bitchin85's Avatar
they didnt start tbi in these till 87. if its stock, its carbed
Old 05-03-2010, 10:49 PM   #6
lester622
oops, thought they started tbi in 86
Old 05-03-2010, 11:11 PM   #7
asphaltburner
asphaltburner's Avatar
Yo!
Given no other variables, and that only the t-stat housing was changed out,...what's the possibility that the t-stat has been reinstalled backwards?
You don't mention coolant temps during operation.
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
Old 05-04-2010, 12:01 PM   #8
wyatt earp
i had problems with leaking before this . i have changed all coolant hoses, new thermostat, new water pump, plugs and wires are not but about 3 months old. so its not running hot. i still have been leaking fluid, but not much(figured out what was causing that).
The dumb thing will run ok and then just die on me. yesterday it died when i was going up a hill. its like it will not power down to a lower gear and when it finally does, it dies or almost dies.
If i stomp on the gas, it sputters, if i gradually ask for gas it does ok.
Wish i could figure this truck out.
Old 05-04-2010, 02:22 PM   #9
1974ChevyC10
Overworked and Underlaid
1974ChevyC10's Avatar
i hd this problem on a 74 i used to own basically if i stomped the pedal it would fall on its face like it had no power but if i gradually gave it gas it ran fine and going uphill it was lose power.turned out to be the fuel filter was dirty and needed replaced.changed it out and cleaned all the gunk out of the carb after that it ran like a champ.i would check the fuel filter as well as all lines and give the carb a good cleaning and rebuild if necessary.
I'd rather push a Chevy than drive a Ford
The Beast-1978 C10 LWB
Red-1978 C10 LWB
(Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012
Gone but will never be forgotten-RIP
(Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012
Taken from us to soon but you will live on in our hearts-RIP
1974ChevyC10 is offline   Reply With Quote
Old 05-04-2010, 02:54 PM   #10
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
lester622,
do you have a way to scan the ECM for the temp reading? If not you can try and replace the coolant sensor in your manifold. If it is faulty it will make the truck run rich.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
