05-03-2010, 09:12 PM | #1 |
want to cut springs have ???'s
I want to cut the springs on my truck to lower just because its cheap and my truck rides bad already. I would like to hear from someone who's already done this and also would like to hear the pros and cons to cutting them.
1991 Camaro Z28 |
05-03-2010, 09:31 PM | #2 |
Grandpa in the rustmobile...
Re: want to cut springs have ???'s
you can only cut fronts, i think its better than heating em..good luck ive never done it but may in the future
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
05-03-2010, 09:38 PM | #3 |
Out curiosity/stupidty why can't I cut the back?
1991 Camaro Z28 |
05-03-2010, 09:40 PM | #4 |
Moderator
Back springs are pig-tailed....they wont have anything to retain them if cut.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
05-03-2010, 09:54 PM | #5 |
you can make a drop block (i was going to do it but I couldnt find a longer u bolt for the life of me). Or a drop spring (100$). or torch em or bags
05-03-2010, 10:19 PM | #6 |
walk into any autoparts store with the measurements you need for ubolts and they should b able to fix u up
05-03-2010, 10:27 PM | #7 |
tried napa and they cant get it reasonably ($65) and orielly autozone etc autmatically says 'no'
05-03-2010, 10:33 PM | #8 |
Cruzin
believe it or not the rear springs on my wife's 67 are cut, and my buddy did it to his a couple years ago so it can be done
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
05-03-2010, 11:49 PM | #9 |
Whoa, so there's nothing holding the top of the spring in place?? That doesn't look safe.
'68 C-10 SWB 383 Stroker (Sold 3/2/2013) '87 R2500 LWB 454 TBI converted to Carb |
05-03-2010, 11:53 PM | #10 | |
Shake and Bake!
The fronts are easy, pull them and take a cutoff wheel and cut one full coil off. Slap em back in and go cruise. Check to see if your stock shocks are going to bottom out or not as well. Some guys cut 1.5 coilsoff and say they have not had any issues, but they come out easy so start with one coil and see how you like it. You can always cut more off, but once it is cut...its cut. To tell you the truth, my truck feels better in the front after shortening my springs. But that may just be me.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" |
05-03-2010, 11:54 PM | #11 |
Moderator
WOW....My rear end is puckering just looking at that.
05-04-2010, 12:17 AM | #12 |
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
05-04-2010, 12:51 AM | #13 |
Big Red - Now its a SWB!
I just cut the fronts on my 3/4 ton and they are a bit different, I cut 1.5 coils and got about 2.5". They are a lot tighter fit then the 1/2 ton ones, if I didn't cut them I wouldn't have been able to put them back in without a compressor. Even with the cut coil it was lifting the truck to get the ball joint back on. Oh yeah the ride seems about the same in the front, I lowered the back by pulling out 4 leaves so it rides smoother than before.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's Last edited by Jacfourteen; 05-04-2010 at 12:52 AM. |
05-04-2010, 02:14 AM | #14 |
I cut the rears on my panel as well
05-04-2010, 07:27 AM | #15 |
cut the front one full coil and for the rear get a set of springs from the junkyard off of a jeep and it will drop it four inches in the rear...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
05-04-2010, 11:44 AM | #16 | |
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
05-04-2010, 01:37 PM | #17 |
What model Jeep springs are you reccomending? Is it the Cherokee?
Danny 71 SWB |
05-04-2010, 01:45 PM | #18 | |
Moderator
http://67-72chevytrucks.com/vboard/s...d.php?t=356615
05-04-2010, 02:00 PM | #19 |
I wish I was a cowboy
OK, so you can cut the rear springs...but in the pictures I saw, there's nothing holding them in place...can anyone honestly tell me it's ok to drive the truck with nothing holding the spring to the frame? I realize the bottom is held in place....
-Kris Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway). |
05-04-2010, 02:06 PM | #20 | |
05-04-2010, 02:20 PM | #21 |
Shake and Bake!
Just don't do it, there are right and wrong ways to do things and that is not right/safe in my book. Kind of like there are two way to see if a gun is loaded, you can look down the barrel (Cutting rear spring) or you can pull the slide back and see if one is chambered (Drop springs)
05-04-2010, 07:33 PM | #22 | |
The rear spring would still be solidly mounted on the truck arm so it's not going anywhere. The top portion has the weight of the vehicle resting on it (est 500-750lbs directly above the upper mount) much like the front springs. The vehicle would have to become fully extended for there to be a concern. Even if that happens, those shorter front drop coils that arent held in place by any hardware (top or bottom) can fall out or become dislodged while the rear is held in place. Yes, very short coils up front can fall out if you hit a good sized dip on the highway @ speed. Very short = dropped coils w/an additional amount removed or stock coils w/more than 2 coils cut. If & when that happens, the vehicle will suddenly drop on that side; the alignment will suddenly be way off resulting in immediate steering issues, & that spring is now a projectile that's possibly going somewhere (steering linkage, ricochet off the bottom of the vehicle, fall off & hit another vehicle, etc....) The better choices vs. cutting the rear springs would be building your own lowering block for the rear (or buying some); buying some used drop springs from the classifieds section, or swapping in bags (shorter installed height vs. load capacity). The better choice for the front drop is mild drop springs combined w/spindles or c.member changes.
05-04-2010, 09:49 PM | #23 |
Cruzin
just to say:i agree on it not being the best way of doing it cutting the rears, we plan to buy her a quality lowering kit, the truck is not being drove now anyways i have the doghouse off it and rebuilding the motor that is just some of the crazy stuff the owners before me did to this poor truck
05-04-2010, 10:24 PM | #24 | |
Shake and Bake!
I just want to make sure if we have a member that doesn't have a lot of experience with these trucks to go start cutting up his rear coils cause someone else did it. Like some said above, maybe you wouldn't see any problems with it that way, but I just want to give the safest, soundest advice I can.
"All tyranny needs to gain a foothold is for people of good conscience to remain silent." Thomas Jefferson "You are remembered for the rules you break." General Douglas MacArthur "Support Our Troops And The NRA" Last edited by Leviticus; 05-04-2010 at 10:26 PM. |
05-04-2010, 10:33 PM | #25 | |
Cruzin
